    Page 2 of 15 FirstFirst 1 2 3 4 5 6 7 12 ... LastLast
    Results 21 to 40 of 282
    1. #21
      Janesville, WI
      Nice project and good work!
      I will say though, you southwest guys are spoiled... Rustbucket? Come to the rust-belt. I'll show you 4th gen firebirds with more rust!
      -Shaun-
      L92/T56 Stalker 1711 pounds, LS power!
      73 Buick Century L92/T56 swap in progress
    2. #22
      Oct 2009
      Reno, NV.
      Quote Originally Posted by subtlez28 View Post
      Thank you.
      I used to live on the east coast, so I know what you mean about all the rust. The previous owner/owners decided to fill the rust holes and body repairs with fiberglass and bondo. I did not not expect to have to replace so much, but I guess I should have looked more closely. Oh well, live and learn.....
      I'm not exactly in the Southwest, either. Reno is much farther north, we actually get snow
    3. #23
      Oct 2009
      Reno, NV.
      Quote Originally Posted by CliffS View Post
      Major props and some skill there!! Keep the updates coming. Subscribed.
      Thanks and I will. I checked out your Firebird; looks good. I really like the hood
      rickpaw: Thanks; I was pleasantly surprised to find so many other firebird builds on this site.
      cobraguy65: Thanks. I was a little overwhelmed at first, but decided to start cutting and grinding. It became easier as I continued fitting the metal.
      CruizinKev: Thanks
    4. #24
      Jul 2009
      Oceanside, Ca
      Very Nice work with the Quarters and Roof, my buddy has a 69' and boy he is never happy with that multi piece bumber!! i'll keep checking your progress. hope to see more posts soon.
      -Leon-
    5. #25
      Oct 2009
      Reno, NV.
      Quote Originally Posted by 67 Camaro View Post
      -Leon-
      Thanks I hear that the 67 is not that much easier to get right. I guess we'll see how it goes.
    6. #26
      Oct 2009
      Reno, NV.
      Making a little progress. I decided to cut away the inner edge of the outer wheel houses so that I could cut and tuck the rear quarters in a bit (I did that before I set the quarters on). I'm hoping to stuff some 285's back there.
      I started by laying down some thin masking tape to mark a straight line.
      Then I cut straight lines with my airsaw every inch or so.
      I was able to bend each section by hand and follow up with just a little hammering to get the edge to sit flat.
      I then spot welded.
      Cleaned up with some sanding discs and sprayed a light coat of Zero Rust.
    7. #27
      Ramona, Ca. San Diego area
      Hey 67rstbkt,
      How was the after market panels? Did you have a hard time making everything fit like it should?
      67 Camaro convertible (Jinx)
    8. #28
      Feb 2006
      Idaho Falls, Id
      Nice progress. I always like seeing picks of panel replacement
      Traven
    9. #29
      Oct 2009
      Reno, NV.
      Quote Originally Posted by 67 ls1 vert View Post
      Hey 67rstbkt,
      They fit alright. The driver quarter sat almost 1/2" too high when I first set it on, but after cutting the bottom a little, I was able to get it to push down. The passenger side fit on with less hassle. The roof needed some trimming on the drip rail edges. Basically, I just installed,removed, tweaked, and installed until I liked how it fit together. I used self tapping sheet metal screws to hold everything together. When I was happy, I started welding, removed the screws, and welded in those holes as well.
    10. #30
      Country Flag: Costa Rica
      Subscribing!
    11. #31
      Jan 2010
      SLC. UT
      looking good
      Jeff -- 96 Mustang - 2V Stroked Modular Turbo // 13 RAPTOR // 67 Mustang Fastback build - Coyote 5.0
    12. #32
      Oct 2009
      Reno, NV.
      Some updates:
      Messing around with tire options....
      Here's the center section I spliced in from a Camaro. Definitely not perfect, but I'm still learning. Plus I inhaled too many paint fumes the day I did this.
      And yes, I filled in the gaps with more weld.
      USC all metal filler
      That's all for now. I'm working on cleaning up the underside. I should have that in epoxy primer and Raptor bed liner soon.
      Joe M
      '67 Firebird
      My build thread: https://www.pro-touring.com/showthre...irth&highlight=
    13. #33
      looking good!
      Feb 2008
      Detroit
      Nice project, will be following this build closely!
      Cheers,
      Brian
      '72 GTO.
    15. #35
      summerville,sc
      people must have run out of chevys. love that so many people are doing pontiacs. keep up the good work. you plan to keep the 400 in the car?
    16. #36
      Oct 2009
      Reno, NV.
      Quote Originally Posted by GM_muscle View Post
      Thanks, and yes I'm sticking with Pontiac. I decoded the motor and it's around a 1971 motor, so not original to the car although the car was an original 400. I'm going through my budget and options with it. I don't think I can afford the forged stroker kit ($2000) and the aluminum heads ($2,xxx), so I'm thinking of doing the stroker and ported stock type heads now. Hopefully, I can get going on the motor soon
      gto406 and GM muscle: Thanks
      Joe M
      '67 Firebird
    17. #37
      Oct 2009
      Reno, NV.
      Some updates. I finished cleaning up the underside. I used Dupont epoxy primer and followed up with Raptor truck bed liner. I also got the sub-frame apart, cleaned up, and all seams welded solid. It's at the powdercoaters right now, I should be getting it back today. Here are the pics.....
      Joe M
      '67 Firebird
    18. #38
      I wouldnt be too worried about going to the Kaufman heads. On my fathers 68 Firdbird that has a 498 stroker pontiac in it they used Edlbrock heads and the car runs 11.0s on stock stlye suspension. Dont know if you need or want more.
    19. #39
      Ive been following your build and it looks good and things seem to be progressing nicely. Keep up the good work.
    20. #40
      Oct 2009
      Reno, NV.
      Quote Originally Posted by 69fbodyproject View Post
      Nope, that's about where I want to be. I'm still considering my options and doing research. It's looking like I'll do the stroker and stick with iron heads. I really want to go aluminum, but I want to get this car closer to being done something in this next decade. I can always swap the heads later on.
      Joe M
      '67 Firebird
