      Dec 2008
      TR6060 & LS3 into a 69 Camaro
      Anyone have any comments or used the TR6060 trans yet? Know if it's a P.I.T.A. to deal with / install in an F-Body? This is sorta a repeat of a previous post of mine but I'm hoping for a little feedback before dropping any coin on a trans. I want to keep it a 6 speed and try to keep it as simple as possible AND not break the Bank in the process.
      Again, Thanks for any replys.
      Marc
      Jul 2003
      Anaheim Hills, CA
      You don't want to mess with a TR6060 (one out of a new car).. the remote shifter deal would be a PITA and there are other issues.
      Now they do make a T56 Magnum which is the aftermarket version of the TR606.. that's what I have in my car.
      Is that what you were refering to?
      1968 Track Rat Camaro:
      Dec 2008
      No, not exactly but I'm willing to consider any option. The TR6060 i mentioned is being offered at a very good price, $1,500 and thought I might be able to shoe horn it in.
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by NVR2L8 View Post
      It might.. but as you can see it's quite different.
      The bellhousing is integral to the trans, that's not a big deal since you're putting it behind an LS3.
      The remote shifter would be.. a challenge...
      The way the driveshaft mounts to the TR6060 is different as well.. not the typical "yoke" deal.
      I suppose it's possible, but hard enought for Tremec to offer a seperate aftermarket version (the magnum).. what is the TR6060 out of?
      Here's the one out of a new Camaro.
      Dec 2008
      The TR6060 I'm looking at is also out of a 2010 Camaro.
      Jul 2003
      Anaheim Hills, CA
      Then what you see above is what you'll have to contend with.
      Think about the shifter arrangement and consider how you will mount a driveshaft.
      The crossmember mount also looked to be different from the T56 Magnum.
      Dec 2008
      Does not appear easy to incorporate into an F-Body Always a choise between $ and labor.
