Results 1 to 20 of 28
04-16-2005 #1
Soft brake pedal problem - new 4-wheel manual discs
I've purchased and installed the Touring-Classics front Hybrid kit and rear kit for my '70 Nova. This is a manual drum to manual disc conversion. Today I finally got around to installing/plumbing the master cylinder and bleeding the entire system (after bench bleeding the master cylinder).
I've bled the ENTIRE system 3 separate times (no air bubbles at all) but the pedal is still VERY soft. My bleeding order is RR, LR, RF then LF. On the first stroke the pedal travels at least half way before I feel ANY resistance. If I pump the pedal a couple times I get decent pedal, but not what I'd call 'firm'.
I've read that I should tap the calipers with wood blocks to release any trapped air, but after 3 complete bleedings I can't imagine there's any air left.
Any thoughts on firming up the pedal would be great. I can't drive it the way it currently is.
Dan
