      Waterloo, Ia
      wilwood master cylinder question?
      Will a wilwood master cylinder and proportionaing valve work well for a stock front disc/rear drum setup on a 67 GTO? Im going to hold off on my disc brake package and rear axle until next fall when i have the car on the road. I however need a master cylinder and proportioning valve to put this car on the road. Ive already got he stock front discs and rear drums on my GTO so im just going to use them. So will a wilwood master cylinder, with no power assist, work well here? Also what size bore should I go with?
      -Nick
      -1967 GTO I drive and race
      -Build threads:
      Aug 2003
      Yes, with a prop valve is will work fine.
      We have the master and prop valves in stock.
