    Results 1 to 1 of 1
      Sep 2009
      Arizona
      GMR XM series Rod Ends/ Heims
      The challenge-
      How can one Rod End set a new standard in Performance?
      The solution-
      Each Xm series Rod end is manufactured with quality control in mind. From the first to the last each unit is produced with a high heat resistant Nylafiber liner and Chromoly Shell. This combination is derived from its racing background and creates a strong precision joint. Each unit is assembled with intense heat and pressure that adheres the injected liner to the race. This process creates a liner that will not become dislodged over time and adds some required reliability to your suspension.
      The Results-
      4130 Chromoly outer Race
      5200 Bearing steel precision machined ball
      Nylon based Injected liner
      Strongest Rod End on the market
      Tight fitment for reliability
      Many sizes and applications available
      Available online through theGMRstore.com at the link below:
      http://www.thegmrstore.com/xmsech.html
      For Technical questions or sales please contact [email protected]
      Jason
