      Feb 2009
      Long island, New York
      longer studs for 69 f body
      can someone find me a link for longer studs for my 69 camaro, i have a set of wheels that fit perfect and the backspacing is fine but the studs are not long enough to get a bite with the lug nuts thanks-dom
      Dom Buffa
      Dec 2008
      Jegs!
      Oct 2005
      Corona, CA
      We could also order you a set.
      Oregon
      You can buy a OE replacement, overlength stud for your application...Dorman #610-157. It's a 7/16-20 press-in stud with a 2-1/8" under head length.
      If you want to upgrade to M12 or 1/2-20, there are limited options without needing to resize your hub/axle flange wheel stud holes, so I would typically plan on some machining if you choose to go that route.
      Tobin
      KORE3
      It's what I does.
      Feb 2009
      thanks guys, i found a set on jegs, i should have looked first thanks-dom
      Dom Buffa
