    Results 1 to 20 of 22
    Thread: Snow tires
      Connecticut
      Snow tires
      Hey Guys, I am looking to get some snow tires for my wifes 06 malibu ss and was wondering if they are worth the money? i have never driven anything with snow tires before so i am not sure if they really help or not. thanks
      Paul Krol
      1968 Camaro
      Sep 2001
      Accord, NY
      I say yes - the tread and compound make a difference. All season tires are really 'most season' tires.
      68 camaro - SOLD
      Rustburg, Virginia
      A good "snow" tire is self-cleaning, and that in itself makes them worth it. Some of the "all season" tires will let snow pack in the treads and then they aren't worth a hoot.
      Jul 2007
      Calgary, Canada
      Huge difference.... get them.
      Dave
      68 Corvair coupe
      65 Impala SS
      64 Corvair Rampside
      62 Corvair Greenbrier
      Asst. daily drivers
      http://www.sourceboards.com/
      Ontario, Canada
      My son uses them and loves them.
      Keep in mind that there are two grades of winter tires. The less expensive is designed primarily for snow, while the more expensive ones are designed for use on ice. Either one will wear quickly if used during the summer months.
      Ken
      My other car is a Vega.
      Aug 2005
      Hamilton, NJ
      Yes, get 4. Maybe winter rims if you plan on keeping it a few years
      Scott from NJ.
      Vent Windows Forever! ...
      Connecticut
      thanks guys so should i get studded? these will be used only during the winter. I am also gonna get some steel wheels to put them on to make swapping them easier. so should i go studded or not that is the next question?
      thank you
      Paul Krol
      1968 Camaro
      Aug 2008
      Pgh, PA
      If you get something like "Blizzaks" you probably would never need studs, and I would avoid them. I would put them on extra rims if possible, wait until you have to for installation, and take them off as early as you can. The rubber compounds are pretty soft, and the tires wear pretty quickly. But they do make a dramatic difference in the snow and ice.
      Auburn, WA
      I wouldn't get studs, unless if your area gets very icy. They don't do a thing in snow, and chew up roads pretty fast.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Juneau Alaska
      I agree. Studded tires are ok but I've had just as good result from using the blizzaks and also the Michellin version. My wife drives a front wheel drive car in the ice and snow that we get here in Alaska with minimal problems
      68 Mustang Coupe
      392 Stroker
      TKO600
      on and on...
      Southern Indiana
      Go to www.firestonecompleteautocare.com to look for your size and closest dealer you can also get them in most sizes from Tirerack.com.
      Honestly the blizzak set the bar for all other winter tires, and used to have, but not sure any more, a change over policy from winter to summer and back for free/reduced price.
      My Brothers 2000, Lincoln LS was HELPLESS in any type of snow/ice. with them it acted like billy goat according to brother.
      Sep 2001
      Accord, NY
      Studded tires are a bit slippery on dry roads and really only help on ice. I'm very satisfied with 4 snows on their own rims.
      68 camaro - SOLD
      Rustburg, Virginia
      Quote Originally Posted by Rick Dorion View Post
      I agree 100% with this statement.
      Connecticut
      Thank you all so much, i will go with the no studded tires on there own rims here is another one for you her car has factory 18 inch wheels on it and 225/50 -18 tires should i get snow tires in the same size? thank you
      Paul Krol
      1968 Camaro
      Aug 2005
      Hamilton, NJ
      With that size, yes. Some applications it is good to go a bit narrower, but I don't think that would be an option for you.
      I had good success with dunlop snows, as well as pirelli and michelin, and another brand that just escapes me right now. the blizzaks are nice but IMO they wore too fast. they might be better now.
      Scott from NJ.
      Jul 2007
      Calgary, Canada
      See what sizes you can get? I know for my truck just recently I had issues getting snow tires for a larger wheel? Might be more available for cars, not sure.
      Narrow is better in the snow as stated above.
      I've used high end Michelins and Pirellis both great, never used Blizzaks.
      Dave
      68 Corvair coupe
      65 Impala SS
      64 Corvair Rampside
      Asst. daily drivers
      San Antonio, TX
      I lived in Colorado for 11 yrs and had snow tires from the first winter season.
      The last 6 years I used studded tires on the rear of my SS, and it was by far the best investment I could have made.
      Granted that was at 6,500 ft above sea level, so plenty of potential for ice.
      I suggest an aggressive 'ribbed' or 'line' type tread up front, kind of like a tractor front tire, the grooves help the steering, the rear tires need to stay behind the car for the best control, the more open paddle type tire, the better (IMO).
      If you get all 4 to match, get the open tread design on all 4. I prefferred not to stud the front tires as the wear on the corners faster, once the front tire throws one or two studs, you need to pull them all out (front only), or replace the tire.
      You could have studs shoot thru your inner fenders (this takes about 20K miles to reach, depending, BTW)
      I had 2 studs perforate the rear inner fenders, probably due to tire spin (?), or worn tire.
      If you state allows studded, get them, you can stop, go, and turn with all the control you would want.
      I used a 255/50/15 for summer and a 205/70/15 for winter I had 225/70/15s before, and liked the 205s better.
      The narrower snow tire will cut thru the loose snow layer faster, and get traction on the harder surface below.
      I kept separate wheel/tire sets, it extends the life of both of them to years of use.
      They look like old Jeep CJ tires, but they work fantastic, you should see some surprised people at the ski resorts, plowing through like a 4WD with those tires.
      Snow tires are not meant for summer temperatures, the rubber is too soft, and at extended highway speeds, they buildup too much heat, highly NOT recommended leaving them on in warmer months.
      Aug 2008
      Pgh, PA
      Having used studs in the past, and "snow tires" (like Blizzaks, Michelin X-Ice or Alpin, etc) more recently - if it's really icy, studs work well. If it's not, studs are actually a disadvantage. Driving multiple vehicles (both front wheel drive and rear wheel drive in addition to AWD) in the northeast over varied terrain (hilly in SW PA, flat in central PA, NY and Mass), my experience is that unless you're in really high elevation with tons of ice all the time, the newer versions of snow tires like Blizzaks have pretty much made studs irrelevant. They're better all around than studs. Having a second set of wheels is exactly what I recommend as well. Never lived in CO but spend a reasonable amount of time there. Never had studs there and never had an issue, but I'm sure living there is a lot different. More extreme conditions can call for more extreme solutions. Studs? Last time I installed studs was back in the 70s.
      Be careful though. Some states either prohibit studs altogether or only allow them during specific time periods. They are pretty rough on road surfaces, and frankly in dry weather they are less safe. YMMV
      Dec 2007
      michigan
      I have 18's on my bonneville for summer, but have 16's with snows mounted to them for winter. If I were you, I'd get your snows on a set of 16's since you buying the rims anyway. From my experience, the narrower tire and taller sidewall are a huge benefit when running the 16's in the winter. you have more give with taller sidewall and for snow conditions, the more the tire is able to flex, the more it is able grip. Also, the rims and tires will be cheaper, and you will have a better selection of tires to choose from. Plus, you can run lower air pressure with a 16 which also helps the tire flex and grip.
      I am currently running a set of Hankook winter I pick tires. They are cheaper than most, but perform awesome. they really shine on icey roads. they have a directional pattern, and are quiet on the road. Every tire has its stregths, and these are braking, ice, and lateral control. They give up a little in traction for taking off, but the benifits of once your under way was appealing to me. plus, they still take off way better than any all season tire ever could. They are not the best tire out there, but do all the things I need.
      what ever tire you get, make sure it has a lot of sipes in it. This is what helps grip in icey and hard packed conditions.
      2005 CBR 1000RR..."mostly stock".
      1968 camaro... "in the works".
      Oct 2007
      ridgefield ct
      i'd get a set of 16 steel rims, this way if she hits a chunk of ice or a rock/curb you have the extra sidewall and you won't break the rim.
      we don't get enough ice to warrant studs especially given the capabilities of new winter tires. and i think they're illegal in CT. i've been running Nokian RSi's for 5yrs and just got the new R's. they are great tires, ice and snow. i've driven ice-x, blizzaks, and the dunlops and IMO the nokian is better. the michellin are only good for one season due to the thin super soft outer layer. the nokians i actually drove on during the summer w/out any extra wear (no money for summer tires). 2 of the tires lasted 5yrs and the others 2 and 3 years (6 tires/5yrs total)
      the nokians are also known to handle quite well even on dry roads. the only weak spot i've found on them is light rain--they take a little longer to stop and start. heavy rain, light/heavy snow-no problem. but they are extremely predictable and easy to drive on.
