New to Pro-Touring
- Jan 2005
- 64
New Arm cross shaft does it need flipped ?
I put in my new Pro Touring Fbody Upper Arms and the passenger side which already had like 3/4" of shims under it now with the car on the ground and the shims that were in the stock arm in the same locations with the new arms the tire is obviously tilted out at the top. That is Positive caster right.. Seems like dave told me to set it at -1 .... The shaft is offset on the arms so do I need to roll the shaft 180 degrees on the studs and put it back to get rid of some of the shims ? I am taking it to the alignment shop tomorrow and was hoping to get a an answer on this so if I need to flip it I can do it myself here and save them the trouble and me the added expense...
