    Results 1 to 1 of 1
      Jun 2009
      Hellwig Pro-Touring Sway Bars for 68-72 A-Body Now Available
      Hellwig's Pro-Touring rear sway bar P/n 55868 is now available for 68-72 GM A-body applications. This kit relocates the sway bar from the lower control arms to the rear axle, which improves handling by allowing the suspension to freely articulate. The sway bar is made from 1-1/8” diameter alloy tubing to reduce weight and incorporates 3 holes to adjust roll stiffness so that the suspension can be tuned to match your suspension upgrades and/or track conditions. The sway bar is connected to the frame with adjustable end links that accommodate stock or lowered ride heights and incorporate hourglass bushings to allow 5X more articulation than a straight cut bushing. The end links are connected to the frame with our integral clevis/tailpipe hanger (pat pending) that allows factory exhaust hangers to be used with the kit. The kit includes polyurethane bushings and all hardware required for installation.
      p/n 55864 for 64-67 GM A-Body applications will be available later this month. This will mount the same, but incorporate a 1-1/8" diameter tubular sway bar engineered for the 64-67 A-body frame.
