Results 1 to 20 of 20
12-01-2009 #1
Ballistic fab tube clamps.. Application
On my panhard frame drop Im running a support going from drop to opposite frame rail . Id like to make it removeable. Id like to make tube clamps like the Ballistic fab ones ... Ok Ive already started... But would these be ok in this application..
12-01-2009 #2I think that's a pretty interesting coupler, but I can immediately see some problems with it.
First, it probably isn't meant to be in any kind of bending situation, tension/compression only.
Second, the fasteners are in single shear. Also there are a lot of sharp transitions in the stressed region where you will get some stress risers.
I think you could accomplish the same thing with a kind of interlocking Y/I system. I'll sketch something up to give you an idea. It would be a heck of a lot easier to machine too.
Having said all of this, I have no idea of the loading on a panhard cross brace. I've calculated some estimations but these are for static loads and I can't wrap my head around how the whole panhard assembly gets loaded in a mild impact situation (for instance a rough transition from the street to a bridge, or even a pothole). Maybe the whole setup doesn't see much loading in this situation, or maybe its highly dependent on type of suspension.
12-01-2009 #3These clamps are sold for rollbar applications where tubes need to be removed for access. Ive seen em used on xtreem 4x4 in some critical rollbar areas. that is where I came up with using them like I want,, Id like to see that scketch before I get too involved in what Im making...
12-01-2009 #4This is what I was thinking of. You could do this I think in two setups per piece. One thing I have learned the hard way though...rarely is it worthwhile to go to the trouble to fabricate something when a reasonably priced off the shelf item will work.
12-01-2009 #5Nothing says "I built this" better than tool marks and dykem blue..
12-01-2009 #6
