11-30-2009 #1
- May 2006
- Richmond VA
- 74
Using Adj. Lower Control Arms to Set Pinion Angle?
I have UMI adjustable lower rear control arms and have welded/boxed the upper arms on my 66 GTO. I need to raise the diff pinion angle up 1.5 degrees to match my new T56 transmission install. It seems most folks using adjustable upper arms to set the pinion angle, though I presume using adj. lowers would work just as well to this end, right? Are there other geometry complications at hand by shortening the lower arms a hair that I should be aware of in terms of strip traction or track/street handling? Thanks!
66 GTO: The Palette...The paint: E-heads, 428/440CID, Headers by Ed & 3" x-pype, T56 6 speed trans, 12 bolt posi with 4.56's. 17" Rocket Racing Booster wheels and 245/45/17 and 255/45/17 Nitto555 tires. C5/LS1 disc brake setup, hydroboost, Jeep GC fast ratio steering box. 1.25"/1" sway bars, adj Umi tubular rear LCAs, SC&C adj F uppers with Howe BJ's, 1" Eibach lowering springs...
68 LeGTO Convert: first car!
70 Cutlass Rallye 350: 54K orig mile survivor!
73 International Scout II on 33's: daily driver
78 Trans Am WS6/W72 Bandit Edition 4spd: The one that got away :(
11-30-2009 #2
