Thread: Underbody paint question
I really need some help deciding what paint to use on the underside of my car. It has a layer of Lizard Skin Ceramic on it and I want to seal it up with something semi-gloss black. I am torn between using Wurth underbody seal black or just regular paint. Please help with specific brand and product info so I can order some paint and move on with my project.
1966 Chevelle SS "Thumper"
Run 10's, turn corners and stop when required....
Used to be known as Russ85MCSS
11-23-2009 #2
- Nov 2007
- Phoenix AZ
- 119
You can always call up Lizard skin and ask them for some pigment?
If you still have some Lizard skin left over I can send you a water based carbon black pigment to turn the LS black.
This is the same pigment we use in Firewall, our ceramic coating to make it grey or black.
Then all you do is mix the black with the the ceramic coating you have left over, the apply another coating on top of the white coating you already have and you are golden!
Send me an email and I'll get some black out to you, no charge.
[email protected]
ANT
11-23-2009 #3I appreciate the offer but I dont think pigment is my concern. My LS is not white, it is the dark grey. It was supposed to be ceramic not sound deadener. Did I get the wrong stuff?
The Lizard Skin doesn't seem like it will keep moisture out. I had some sanding water drizzle down on it and it sucked it up leaving a white stain and it willl not come clean. I want to seal it up with something else but don't know what to use. I was looking at the Worth underseal because it is a plastic/rubber base and is an actual sealer. I guess regular black paint will work to but I am a rookie so I do not know what to buy. I have a nice air compressor so I can spray. I plan to drop the frame back out from under the car to re-coat the underside. It would be nice to find a paint that I can also spray the floor on the interior of the car. I thought SKS stoneguard or Zylotone would work well in the trunk.1966 Chevelle SS "Thumper"
11-24-2009 #4
- Nov 2007
- Phoenix AZ
- 119
The water stain is due to the latex to iller ratio of the product. IF they use any mineral filler at all, it can soak up any moisture that comes in contact with it.
I think applying the wurth coating, or eastwood coating on top of the Lizard skin would be a good idea.
Remember though. You need to wait at least 30 days for the lizard skin to cure. If you apply a water tight coating on top of it without allowing for it to fully cure, the new coating will trap moisture in the old coating and could promote rust.
Hope that helps!
ANT
11-24-2009 #5
