    Page 1 of 5 1 2 3 4 5 LastLast
    Results 1 to 20 of 88
      St. Louis
      69 Camaro LS3 transplant
      ;) Hi Guys
      It's been a solid car for the last 7 years, enjoying many miles on various cruises and Power Tours. The 383 stroker and Tremec 5-speed performed well, but I've had the LS bug for years now. Drivability, horsepower, reliability, gas mileage, etc., plus the fact I wanted Air Conditioning for the cruise home. Power Tours are great, but as some point you just want cool air and quiet surroundings. The time has come.
      2009 Power Tour with daughter, priceless.
      Stroker before the pull.
      Thanks to Craigs List, the 383 is going to a new home.
      I know, should have pulled front clip first, but I had to remove the motor quickly for the new buyer.
      Removed old heater core, and took steel "bolt-in-plate" from Vintage Air package and decided to cut and weld into place for smoothing the firewall. I know many folks hide the lines underneath the fender well, but I decided to go this route. Just going to keep in simpler and use all the hard lines from my Vintage Air kit as they were engineered to by used. First time ever welding so this was a learning experience for me. I can say afterwards I know more now.
      I'm much further along than the photos show, but will have to post more later. I hope you all enloy this as much as I've enjoyed reading all the posts from everyone elses builds. Feel free to ask any questions!
      St. Louis
      More of the update
      My first time welding on sheet metal was a learning experience for sure. Made the mistake of buying .30 wire, and kept blowing small holes on the metal. Panel going in was a little thicker than factory sheet metal, so the holes ususally ended up on the factory skin. Switched to .24 wire and finished her up, and filled any pin holes inside and out with 3M sheet metal epoxy, the stuff they glue panels on with. My cousin owns a body shop so access to the guys at the shop and supplies sure comes in handy. Firewall is in primer now and the subframe is completed with POR 15 satin black.
      Notice the 10 year old Merrills!
      Next step was to throw together some DSE stands and move the car for first mock-up with engine and tranny going in.
      For motor plates I went the route of Car Shop Adapter plates with 1" set-back and Energy Suspension Mounts. Hooker Headers and Competition Engineering Cross Member kit from summit for $50. I figured the money I save from making it myself helps pay for the new Hobart Welder.
      Besides, welding, cutting, grinding and fabrication is 1/2 the fun.
      I'm having a blast on this project!!!!
      Dunwoody, GA
      Looks great and I'm glad you're having fun. I like the green paint. The first two pics made me think it was black. Green looks good on the 1st gens.
      Trey
      ~ Jon Hammond
      Phoenix, AZ
      Jon -
      Are you running the Kwik pulley setup for the A/C? If so, what are your thoughts about it? I was debating the same setup for my car, but wasn't sure if in person the brackets had more of a function over form look to them.
      ~ Jason
      St. Louis
      Kwik Bracket
      Jason
      The bracket for the compressor works great. Very solid mounting system.
      May 2008
      SoCaL-Pico Rivera
      Dam this is nice. Keep up the good work.
      Ramona, Ca. San Diego area
      Hey Jon, how close are the headers to the steering gear box?
      67 Camaro convertible (Jinx)
      St. Louis
      Close
      The headers are 3/8 from the steering box. I read this selection of adapter plates and motor mounts would allow this to drop right in, but wish to confess the frame had to be notched for clearance of the alternator. I only had to drop a small pocket in the frame about 1/4 lower since it wasn't hitting by much.
      Now maybe I don't have a factory original GM alternator?, don't know for sure. Didn't feel like researching or shopping to solve the problem since my buddy recently purchased a Miller Plasma Cutter and I'm looking to weld anything in sight.
      Jul 2009
      Graham NC
      Great loking project. How did the crossmeber kit work out that you got from Summit? Do you remember the part # for it?
      Thanks, Dion
      USA
      That is soooooo nice !!
      Thanks for the picks.
      I gotta' do this one day..so your info helps..
      Where did you get the LS3 ????? Craigslist ? Turnkey ? Ebay ??
      Jeff Tate
      U.S.A.
      summerville,sc
      looks killer keep up the work.
      San Antonio, TX
      Nice attention to detail, it is going to look brand new.
      St. Louis
      Crossmember Info and Pics
      The crossmember is #3601 Competition Engineering from Summit. Regarding the engine builder, Regal Performance in Texas.
      First step to the crossmember installation was to relocate the emergency brake pull cable from inboard side of drivers side subframe to outboard side. Used a Lokar Universal emergency brake cable that originally was purchased for the Kore 3 C5 brakes, but now I rerouted for crossmember clearance. Worked out so nicely I realized it should have been done this way from the beginning.
      Area cut from
      Outboard relocation
      Now for the crossmember. I welded some plates which extend from the frame up to just below the floor. My decision for this was for two reason, 1st being this put the crossmember high enough for a direct exhaust shot rearward from the headers. Should keep the pipes tucked up neatly to the bottom of the car.
      2nd, having it up this high gave me access to drilling holes and using 1/2 bolts from the inboard size and while able to access the nuts on the backside of the plates. Should make future installations and removals easier leaving this main part as a bolt in. I'm very happy with how this turned out, especailly for the price.
      Aug 2009
      Crofton, MD
      Great job so far!! Keep us posted!
      GM EFI Tuner
      Apr 2007
      Huntsville, Tx
      What about..
      the angle of the engine and transmission. This isn't going to kick the rear of the tranny to high? Just courious? Build is going great. Your sure work fast.
      Sam
      69 Firebird convertible T/A pro-touring custom, Now LS1/T56 six speed, 3:42 Eaton posi, 18" Iforged wheels, 04 GTO interior.
      www.fquick.com/SamHatco
      Jack of all trades, master of none.
      St. Louis
      Thanks Sam
      Actually I started the first of September, and my progress is a ahead of my posting so it looks like I'm kicking _ss. In reality I've spent quite a bit of time on this and my posts are catching up.
      The engine sits at 4 degrees now, but I'm thinking once all the front end is on with the extra weight the angle should settle another degree to probably 3, which is perfect by what I've read. The rear end is gonna have to be adjusted though cause it's sitting at 0 degrees right now. That part can wait till the end.
      I'll post a little more tomorrow with some pics.
      Charlotte
      This going to be on the Power Tour '10?
      2014 Chevy SS LS3 / 4 Door
      Apr 2007
      St Joe, Mo
      Quote Originally Posted by Jon69RagTop View Post
      Which Hobart are you getting. I just bought a 140 handler a few weeks ago. I love that little guy. I am just learing to weld and having an awesome time. Your car is looking awesome.
      Ryan
      1969 X11 Camaro- Peelin paint, rust, the whole works
      Nice job, it looks great. It should be a fun car to drive when your done.
      St. Louis
      Sorry guys, works been killing me!
      Hell YES this is going on Power Tour 2010. One of the reasons I took it off the road so early this Fall was to insure she'd be road-worthy early Spring. Regarding the Hobart, it's a 187.
      For those of you who might not know, LS motors have an electronic output from the harness to pulse an electronic speedometer and tach. I wanted to keep the original dash though and try to make it look as original as possible. I'm very satisfied with the outcome.
      First picture represents the removal of the bezels which hold the gauges in and house the blinkers/idiot lights. Stripped these down and used my dremel to carefully remove just the clear portion of the lens without cutting into the black portion. I also used the dremel to cut out the awkward shapes on the back side of the dash which mirrored the back side of my factory fuel gauge and speedo. I needed to create smooth places for new mounting plates.
      Backside
      Once this was done, I took my gauges to a buddy with a machine shop and had him trace and duplicate the flat portion of each gauge from aluminum to create new mounting plates.
      Once these were painted flat black and I resprayed the bezels, walla!!!! I'm really happy with the stealth look.
