Results 1 to 11 of 11
Thread: Roto Zip????
08-25-2004 #1
Roto Zip????
Does anyone know if thier is a metal blade for Roto Zips? I need something to cut a complicated hole. I don't have a Dremal or a plasma cutter.
:3gears: Rob Jones Project "Wild Goat"
08-25-2004 #2I have no idea what a roto zip is. What material are you cutting? If it's aluminum, just use a regular router. If it's steel or stainless, layout the hole and use a hand held die grinder.
-Matt
08-25-2004 #3I'm cutting sheet metal on the rear 1/4. I want to do some custom flush mounted marker lights. But the shape has alot of complex curves.
08-25-2004 #4Can you use a jigsaw? It's hard to say without seeing exactly what you're doing, but I'd say a jigsaw to rough it out, then either a file or diegrinder to finish.
-Matt
08-25-2004 #5
