    Results 1 to 20 of 30
      My 69 Camaro Rocks
      Hi, thanks for looking in on my restification. I'm merging the old with the new like 4 wheel disc brakes, rack & pinion steering, LS1 fuel injection with Luanati cam, Comp push rods and valve springs. 4L60 E auto with 2800 TCI converter and a Transgo shift kit. A Moser 12 bolt with 373's. All metal work has been performed by Mike Riggs of Mike's Custom Cars, He does a great job and is very meticulous.
      69 Camaro w/LS1. Start date April 2002, completion date June 2013. But it will be well worth it!
      Oakland CA
      That thing is awsome! Keep us posted on the pro's and con's of the steroids kit when u get her on the road....
      David
      :3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
      1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
      Camarillo, California
      Could you show a pic of the Steeroids kit from the front of the car. I was wondering how much lower than the crossmember it hung down.
      Jake
      Jun 2002
      Long Island, NY
      Welcome to the site, nice ride! Maybe consider some tubular upper control arms for the future.
      The rack and pinion is pretty much the same level. If you look at the pick, the one under the car, up through the tunnel, you'll see there it is about the same level as the crossmember.
      Ralph,
      Thank you and thanks for the time you guys have put into the site.
      I did not catch that. Thanks. Also in that picture you can really appreciate the level of work you went into. Looks great. I was a little worried about the Steeroid kit. I was thinking about doing an entire Martz from chassis. Mine sits pretty low and I was worried the rack would tag something in the road if I stayed with the orginal subframe.
      Jake
      Quote Originally Posted by my69rocks
      Jake, I'll get an actual measurement for you and get back to you. By the way I first found the Steeroids via the Pro-Touring site.
      Mike
      I am still pissed I did not find this site earlier. The money I would have saved!
      Jake
      Jun 2004
      Anchorage, Alaska
      Man that car is gonna be sweet!
      Bill
      68rs mini-tubbed,subframe connectors, 335's on Fontanas
      Thank you David. How has the 10 bolt worked out for you? Is it a first gen 10 bolt? I'm considering rebuilding mine with new axels and everything and running 373's.
      Jun 2002
      Oregon
      That really is turning out nice!! Great sheet metal work, one question though...all that metal work and no mini-tubs?? Ok, one more...is that the WRX blue??
      Tony
      Tony, thank you. Mini tubs would have been nice....but as you know you have to plan and stick to that plan somewhat or things can get out of control. For what I'll be doing, Nitto 255/45/17's will be more than suffient. Sorry can't answer you on the blue paint since it was a custom mix.
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by awr68
      My car is WRX blue.. and i hope i end up being the first
      that color seems a bit lighter.. beautiful car.. im a sucker for blue :D
      1968 Track Rat Camaro:
      Steve, Your car is very nice! Lots of detail also. Don't worry you will surely be first. I'm a while from completion.
      May 2002
      Northern California
      nice Cam
      Hey Mike, he sure does nice work. Will be a nice peice when done. question...is all that goodmark stuff? How was the fit?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Hey Vince, Most of the sheet metal is from DII and some Goodmark. As always nothing ever bolts right up. One qrt. had to have some metal work and the fenders (Goodmark) needed cutting and adding in 3 places. The inner passenger side door had to be separated from the skin, material removed, and door panel adjusted to allow for good gaps. Again, enough can't be said about Mike Riggs @ Mike's Custom Cars, making sure the gaps were great.
      Feb 2008
      Mike,
      Show us some new pics, of your car .....
      Mike I saw the color on your car its a beautiful color. As far as the sheet metal you could give mike the worst reproduction fender and when he was done with it you'll think it NOS
      Beaufort , NC
      1992 Lexus SC400 daily SOLD
      1966 Porsche 912 Outlaw SOLD
      1968 Ford F-100 sb SOLD
