Results 1 to 13 of 13
Thread: Bump steer Hell
04-11-2005 #1
- Mar 2005
- 66
Bump steer Hell
I've never seen such good discussion on suspension anywhere else.
I love this place!
Anyway...
I built my own rack and pinion conversion for my '69 Vette. It works and all but trying to eliminate the bump steer is killing me.
I have the general ideas but it seems evertime I change something it gets worse not better.
So;
Question 1: Is there a good discussion on how to measure and eliminate bumpsteer? A book maybe?
Question 2: How much bumpster is too much? Some people have said I should try for zero, Well, zero what, inches or microns??
Question 3: There are basically 2 bumpsteer errors that I can see, tie rod height and length. Is one worse than the other? Should I try harder to get the tie rod length right and not worry so much about height?
Lastly, is there a way to calculate the correct values for tie rod length and height without buying a $10,000 suspension design program???
Thanks in advance
Keith
04-11-2005 #2
- Aug 2004
- England
- 1,042
What I am doing is measuring the upper and lower A arm lengths, distance between arms upper and lower, distance between heights of arms, take the distance subframe measurments and put them on a large peice of wood now get strips of wood and make the A arms, nail these into the flat peice of wood so they move as they would on car get another piece of wood with the spindle measurements ie were they would be on A arms, also so that now you should see how the wheel travels up and down, now use the measurements of where the rack sits and attaches to the frame and spindle. Now move the arms up and down in the travel of the suspension, on the rack strips make so the nails slide in the rack strips that are where the strips nail into the spindle so as you can see the any movement in slot ie bumpsteer then alter the rack strip up or down or the spindle mount till there is no movement in slot or very little.
hope this is of some help paul67
04-11-2005 #3dennis68 GuestA much easier way is to measure ride height, remove the coil springs and shocks, and use a jack to simulate range of motion. A piece of plywood and a dial indicator will work to measure bumpsteer, you are measuring thousands of an inch. Less than .100" is good enough for most applications although zero is ideal.
Longacre has a real easy to follow procedure for evaluating your results and making adjustments.
04-11-2005 #4
- Mar 2005
- 66
Interesting, I am within .100" now, trying for under .03125" (1/32")
Maybe I'm crazy but it seems that having as much bumpsteer as I have toe in would be really bad!
04-11-2005 #5
