    Thread: LED Headlamps
      El Paso, Texas
      LED Headlamps
      Hi all, just wondering if anyone has seen these new LED headlamps from Trucklite. http://www.truck-lite.com/webapp/wcs...4057&langId=-1
      They are pricey at about $300 each but if it means I ain't gotta cut up anything to make them fit....
      Alex
      May 2007
      Las Vegas
      I saw a bunch of them at SEMA today, mostly in Jeeps. I believe they are bolt in. Maybe a little tweak with the factory headlight ring...
      Rich
      1969 Camaro (in hibernation)
      El Paso, Texas
      Were there any lit up? I wonder how bright they are?
      Dunwoody, GA
      LEDs are the future so give it a little more time and the prices will come down, the applications will go up, and the performance will go up as well.
      Trey
      ~ Jon Hammond
      Feb 2008
      seems promising but it doesnt list a lumens output thats the main concern i would have
      May 2007
      Las Vegas
      There werent any lit up at the show. Even if there were, it wouldn't give a very good idea of light output. You would need a dark room and a white wall to see the light pattern...
      I first saw these lights over on the Harley forum... I think someone had it installed with a camparison photo... I'll go look...
      Rich
      May 2007
      Las Vegas
      http://hdforums.com/forum/touring-mo...eadlamp-2.html
      LED on the bottom, Stock with out passing lamps on the top, both low beam:
      Led high beam bottom, stock high beam top:
      Side by side low beam with out passing lamps head on:
      Rich
      Dec 2008
      Arlington, Texas
      Thanks for the pics; that does looks promising. Unfortunately, as previously stated their website does not list the lumens rating. However, for comparison, their auxiliary lighting product is rated at 2000 lumens; and, it only uses a fraction (1.4a) of the amps that the headlamps (2.5a/4.5a) are rated for. According to Sylvania's website, the Silverstar lamps range anywhere from 700-1700 lumens depending on the application.
      http://www.ledheadlamps.com/81802.html
      I'll be watching closely for a release of the 4651 & 4656 sizes.
      Carl
      '86 GN
