    Results 1 to 9 of 9
      LED tails installed, now lights don't work!
      Hi Folks-
      I just installed a pair of Shiny Hiney tails in my 70 chevelle. Everything functioned prior to me touching it (typical). I hooked up black to brown and red to yellow/green, now my tails do not work. Front lights work fine. Ideas? Thanks!
      MD
      70 chevelle, 427, forged, solid roller
      Oct 2009
      http://shiny-hiney.com/70%20chevelle%20instructions.pdf
      it looks like the mount for the housing doubles as the ground...double check that it's a GOOD ground, or just run it to bare metal elsewhere.
      I grounded the stud with a jumper and no result -- i emailed Wade, we'll see what he thinks. Thanks for your help!
      MD
      Apr 2008
      Bulbs are in backwards
      How many forums are you going to post the same question to?
      As many as it takes to get the answer. There are no bulbs to put in backwards.
      MD
      Oct 2009
      diodes HAVE to be wired to the correct polarity, as opposed to an actual bulb which can go either way.....do you have 12v to the brown wire?
      europe
      when i installed my led tails, i ended up having to change the input on the no load flashers where they plug into the fuse block to get everything to work properly. my regular tails worked great prior to installing the led's as well. now everything works like it should...
      Jeff J. aka JJ
      1969 Camaro
      1952 Chevy Truck
      wir müssen Leben bis wir Sterben...
      Jul 2007
      Olathe, KS
      Quote Originally Posted by OhioProto View Post
      Absolutely correct. A diode (which includes the LED) is a one way street for electricity. From the OP's post I would agree that it's wired backwards.
      Quote Originally Posted by mjdwyer23 View Post
      If you're positive the polarity is correct, have you measured the voltage between the positive wire and the ground you're using?
      I have confirmed the correct wiring with Wade @ SH. I will be checking the ground and installing the electronic flasher tomorrow, I'll check back in. Thanks!
      MD
