      NYC
      What size MC bore when using Hydroboost?
      What size is the master bore suppost to be when using a hydraboost?
      George
      `67 Buick GS 400 Hdtp,494ci Stage 2 BBB,5-speed TKO-600,"The Black Widow"
      Oregon
      What brake calipers are you running?
      Tobin
      KORE3
      It's what I does.
      NYC
      Wilwood 6 piston all around
      George
      Oregon
      I'll go out on a limb and say 1-1/8" bore MC with GM/Bendix hydro-boost. If you specify the Wilwood calipers and piston area that you're running, others might be able to give more specific information based on similar installations.
      Tobin
      KORE3
      It's what I does.
      NYC
      I will get the info but i believe they are the billet SL6R calipers,im running a 7/8 bore master at the moment with manual brakes.
      George
