      Winter Park, FL
      fuel pressure mystery
      I thought I was having vapor lock problems because I was stalling out after the car got hot, so I replaced my mechanical fuel pump with a carter electric along with a pressure gauge. I also had previously insulated my fuel lines and added a 1/2 inch wood spacer below the carb. When the car is cold the pressure gauge reads around 7 psi. When the engine gets up to temp, the pressure gauge reads 0. Car is still running, just no reading on the gauge. I have an aftermarket fuel tank without the factory vent tube, so I thought maybe that was the problem. Even with the gas cap off, it still acts the same. Any ideas? I think I'll have to try another gauge to see if it acts the same.
      69 Firebird Convertible.
      www.stevegarrison.com click Firebird link at bottom of page
      Papillion, NE
      Is it a liquid filled gauge? The silicone expands with heat and equalizes with the fuel pressure.
      Get an old wiggly style gauge, I bet the problem is gone.
      70 Mustang - 489 cid FE, KC ported Edelbrock heads, Modified Victor Intake, Mass-flo EFI, Erson valvetrain, Supercomps, TKO-600, 4.10 9 inch.
      71 F-100 4x4 SB 4x4, 461 cid FE stroker, Edelbrock Pro-flo 4 EFI
      13 Ram Laramie 2500 4x4 6.7 diesel - trailer puller
      Oct 2007
      ridgefield ct
      do you have a return line? what size are the fuel lines?
      Henderson,NV
      Quote Originally Posted by My427stang View Post
      Your car can't run with no fuel pressure. As said the liquid filled gauges are junk for fuel pressure. They will read 0 when hot. Get a non liquid filled and go from there.
      Todd
      Feb 2009
      So-Cal
      or you can say F it and just have fun! That's my vote!
      James
      James Faria
      07 GT500 740rwhp
      Winter Park, FL
      Thanks guys. It is a liquid filled gauge. I guess I'll send it back.
      Sep 2008
      You probably just need to run a return line...
