Thread: Steering u-joint
11-03-2009 #1
Steering u-joint
Posting this for a friend of mine. Here in Norway we have a model Called Ford Sierra Cosworth. It was produced in mid -80's and start of 90's. It's powered by a 4 banger with turbo. Stock 205-220hp. Modified up to 5-600 hp and some more.
His problem is the coupling between the steering column and rack. The input shaft on the rack has OD 11/16" with 40 spline. The column is no problem. Is there any u-joint with this spline inside the joints ?
The Ford rag joint/ coupling is not possible to get from Ford or any other suppliers...
Thanks!
Olav
11-03-2009 #2Borgeson makes one:
https://www.borgeson.com/catalog2/pr...b0b3e2ba5084e4
11-03-2009 #3Thanks!
11-03-2009 #4
