Thread: Weird starting problem
- Dec 2008
- Lehigh Valley Pa
- 1,269
Ok lately my car has developed this rather odd starting problem. I turn the key and it acts like it's dead. But if you hold the key every slow turn of the engine(very slow, like one turn then a pause then another turn.)get lightly more power then all of a sudden it starts. Most times if the battery is bad or there is a weak connection it will get worse as you hold the key in the start posistion, not better. What gives. It is kinda cool because people will say it's not gonna start and as they say that it does, like the car can hear them and doesn't like what they are saying.
1996 Federal Cadillac hearse
1988 Eureka Chevy hearse
10-25-2009 #2Well, a wacky proposal for a wacky problem....maybe your starter isn't putting out as much torque as it should, but it's still enough to just barely turn the engine--as the engine gets going, the angular momentum of the rotating assembly increases and more and more of the torque being generated goes towards increasing the acceleration of the crank, until it finally is moving fast enough to turn over. Instead of it happening virtually instantly, it's drawing it out over a period of time.
10-25-2009 #3
- Oct 2009
- 70
Start off with the easiest. Check all connections including grounds.
Don L
Keep the rubber side down.
10-26-2009 #4
