    Results 1 to 20 of 26
      May 2009
      Iowa
      Manual or Hydroboost?
      Looking at putting some Baer Pro-Plus Brakes 14" front and rear on my 68 Camaro and with a recent engine change my vacuum booster no longer works. Car is 90% street 10% road course/ autocross. I have had people say definitely hydroboost or definitely manual. I dont want excessive pedal effort but also dont want them to lock up really easy either due to such large brakes and a lot of assist. I have never driven anything with a performance manual setup or hydroboost with this big of breaks so hit me up with your opinions
      Auburn, WA
      If it's a street car, go with power brakes. Personally I don't like to feel of hydroboost setups, I prefer vacuum.
      But then again, I prefer manual over anything else - but I know most would rather have power brakes for the street.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      May 2009
      Iowa
      only have 9-10 in/hg at idle, vacuum not an option
      Oct 2008
      I put a hydroboost on my "74 Camaro with Wilwoods and love it. Fantastic stopping power, good pedal feel and easy to modulate.
      Keller, Texas
      I am going with manual and if I don't like it I will convert over to hydroboost later. Cheaper to do it that way than spend the money to go hydroboost just to remove it later.
      Greg
      1970 challenger convert-in process
      1970 barracuda-driver
      Maysville, KY
      I just put hydroboost on my S10 that runs 10's on motor and 9's on spray and love it. I love having power steering and power brakes that will stop on a dime. I got my hydroboost unit off a 93 Astro van for $20 at a local salvage yard. Bought my master cylinder for $30 at NAPA and ordered my lines and fittings from Jegs. Got about $250 tops in it. Line and fittings was the most expensive part.
      Kevin Turner
      Maysville, KY
      3-69 Camaro's
      02 S10 extended cab that's street legal & runs 10's on motor and 9's with spray.
      04 GMC Denali Quadsteer truck black with black 22's.
      04 GTO LS1 that loves to be sprayed and meet imports on the street.
      Henderson,NV
      Quote Originally Posted by gkring View Post
      Not much since you will need to buy a different master cylinder with hydraboost. I have manual brakes on my car and have 3k on the clock with 3 autocrosses and 1 roadcourse race. I like them alot on the race track. Especially if they get some heat in them. Not crazy about them on the street. There is alot of slow speed pedal effort. I'd go hydraboost for 90% street car.
      Todd
      Keller, Texas
      I remember being told by Frank at Prodigy you can use the same master cylinder, I would have to double check that info. I am using a typical wilwood master. I still think it is better to start out with no hydroboost and add it later if you are unsure. That way you know. More plumbing, work, and cost to have the hdroboost. Not saying one is better than the other because I do not know and it matters on the application and personal preference. I agree that in 90% of the cases the hydroboost will be better. I also think that most guys here don't consider themselves in that 90%, right or wrong.
      Greg
      Quote Originally Posted by turner69camaro View Post
      Do you have part numbers? Did it require bracket fabrication?
      Thanks.
      Oregon
      Do what sounds good to you as folks are happy with both. As for the MC, you wouldn't want to use the same one from a manual setup with a hyrdro-boost...it would be like a light switch with zero modulation. You'd also probably run out of stroke due to the increased system gain/pressures combined with the system compliance.
      Tobin
      KORE3
      It's what I does.
      Henderson,NV
      Exactly, I'd want the extra fluid volume allowed by a hydraboost which is a side effect of the larger bore master.
      Todd
      Maysville, KY
      Quote Originally Posted by 68Formula View Post
      Thanks.
      I didn't have to do much fabrication at all on the S10 because it used the same brake pedal rod. What I plan to do on my Camaro is cut the rod on the hydroboost unit weld a 2" or 3" sleave on the rod and then cut a Camaro rod and insert it on the other side and weld it. I used a round track late model power steering pump with remote canister with head mounted bracket from Speedway Motors. I didn't have room for a power steering unit down below to use a factory power steering unit. I think the only other modification would be to make the hole in the firewall a little bigger for the hydroboost to stick thru and it bolts on with four bolts. MAKE SURE YOU GET A HYDROBOOST UNIT FROM A 1990 - 1993 ASTRO VAN! It has a flat bracket and installs flat on the firewall. Most units will have a tilted bracket. You can modify the bracket but it takes forever. I used a late model truck rebuilt mastercylinder part #390257 from NAPA that cost $30. I would recommend going to a parts place like NAPA or some place they can look up part numbers.Below is a list of part numbers for early model mastercylinders that will work as well.
      36306 - GM Camaro 1.125 bore
      39052 - GM C6 Corvette 1.125 bore
      39018 - GM C3 Corvette 1.125 bore - uses deep push rod
      36367 - GM C3 Corvette 1.000 bore - uses deep push rod
      Below is a diagram of how it all installs. I hope this helps everyone.
      Kevin Turner
      Maysville, KY
      3-69 Camaro's
      Oct 2009
      Sleepy Hollow,IL
      I run a SSB electric vacuum pump. A little noisy but I get 22 in. of vacuum. I am probably going to switch to a hydra boost if I can't find an electric pump out of some luxury car.
      CHICAGO SUBURBS
      I've done Hydroboost in like 5 cars now. They all are great! As long as you have power steering I wouldn't do anything else.
      Frank B. 1968 Camaro 355 Procharged 6 speed. 1983 V8 S10. 1984 Monte Carlo Magnusen Charged iron 6.0. Plus a few other junkers!
      Aug 2003
      NO, you need a different master. But what I do offer all my brake customers is a free test. You have a 7/8" master. If you do not like the manual brakes, I will take your 7/8" master on trade for even money on the proper 1 1/8" master you need for the boosted system.
      Henderson,NV
      Sweet......LOL
      Todd
      LI New York
      I had them all. Power , Hydroboost and now manual. It really sucks when you have a problem with hydroboost. I did. It locked up my brakes every time I turned the wheel. I may be a rare case, but there's alot more to go wrong the way I look at it. I just installed a 15/16 bore master with stock disks and I love them.
      Apr 2004
      OKC, OK
      Quote Originally Posted by mnm99 View Post
      Power steering pump was failing or incorrect for use with hydroboost. PS pump for use with HB needs at least 3 gpm to work properly.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Central Valley Ca.
      I contemplated the same on my Camaro, but I left it manual. It stops great and I have 4wheel disc. I don't remember the bores, but I have the ATS kit with the C5 discs up front, and a LT1 rear disc on the back... for what it's worth...
      1969 Camaro..getting closer to being done..I think
      1994 Camaro... Future N.A.S.A racer... maybe
      Victory Circle South West Tour race car (SCCA)
      2006 SS Trailbrazer (Wifes)
      2007 LTZ Chev Silverado 4x4 with the sports suspension package
      Greg is my other name...
      Web page..
      http://www.youtube.com/user/itlbtu?feature=mhee
      New Jersey
      13" 6 pot and 12" 4 pot Wilwoods with manual 7/8" bore mc and love it.
      Like Vegas said though, they seem to work a bit better with some heat, but for me I like to feedback I get when stopping and I've had to halt her from short distances on the street.
      Camaro Convertible Build Pics - http://s447.photobucket.com/albums/qq198/rob07002/
      www.musclerides.com
      Rob Stevens
