Results 1 to 18 of 18
10-22-2009 #1
looking for a compact AC compressor
I've got a pontiac 455 that I want to keep looking fairly stock (no flashy aluminum pulleys or $2000 serpentine systems) but I would like to change out the HUGE axial compressor for something smaller. I know a lot of folk like the sanden unit but I think it may be a little too long.
I am considering run twin turbos, and I would like to mount it IN FRONT of the block, using a v-groove pulley that lines up with the old pulley (outside groove of 3 groove crank). I've got 6 1/8" between the block and the outer lip of the pulley groove. Are there any commonly available radial compressors with a body and clutch length of 6" or less?
The compressors off the old L98 TPIs look fairly short? Diameter is not much of an issue in this location.
thanksGreg
1976 Trans Am SacrilEdge
twin turbo 455
Ttops and 4spd
one of 110 made
https://www.pro-touring.com/showthre...ect&highlight=
https://www.pro-touring.com/showthre...ilEdge-is-free!
10-23-2009 #2
Well, if you don't like the Sanden and want to run turbos, I'm not much help. I used a Sanden mounted in the same location as the stock A6 compressor I had in my 74TA. I had to fab up the brackets. If you want a photo let me know.
