    Results 1 to 8 of 8
      Feb 2006
      South Austin- Texas
      Radiator cleanup
      Folks
      I just bought a used radiator of the aluminum cor/composite tank variety. There is a build-up of slimy orange radiator goo inside.
      What's a good way to clean that out?
      How about the radiator flush they sell from prestone. Its made to use when its in the car ,but I don't see why it wouldn't work for you.
      Southern Indiana
      simple green hot water
      Central CA USA
      do a google search on dex-cool and problems with plugging radiators.
      Papillion, NE
      Spot on, I hate that stuff. Wifes 2000 Blazer in 2002 was plugged as was a buddies Mach when he tried to use the stuff.
      Google "Deathcool"
      70 Mustang - 489 cid FE, KC ported Edelbrock heads, Modified Victor Intake, Mass-flo EFI, Erson valvetrain, Supercomps, TKO-600, 4.10 9 inch.
      71 F-100 4x4 SB 4x4, 461 cid FE stroker, Edelbrock Pro-flo 4 EFI
      13 Ram Laramie 2500 4x4 6.7 diesel - trailer puller
      Jun 2009
      Southwest Florida
      It's fine, but you gotta stick with one or the other. The second you mix it, even with a tiny amount of traditional antifreeze formula it'll sludge up.
      -- Dan
      Southern Indiana
      actually dexcool in early years was formulated wrong and still produced a whiteish crud too.
      I prefer IF extended life AF is needed get the Ford spec G-05 it doesnt crud up or stink bad when old.
      But also look at Evans Coolings NPG line of coolants,,,,SOOOOOOO much better.
      Oct 2009
      Yep Dexcrap is just that, crap. Any of your store bought coolant flushes like Prestone should clean it up. Don't forget to use a nuetralizer after you flush or it'll eat the aluminum too.
