10-15-2009 #1
- Aug 2008
- 167
Need help 9inch with 700r4 tranny.
I just installed a 700r4 with a 9inch rear into my 70 nova. the drive shaft u joints is where my issues are being created. the factory drive shaft is to long by about three inches. so i went to a friends yard and found a drive shaft that would fit the 700r4 and be 3 inches shorter than my factory one. the u joint on the new drive shaft is two long to fit into the 9inch housing. meaning the ridges on the inside where the u joint rest will not allow the u joint to fit. looking at my factory u joint it is much smaller than the new u joint from the new drive shaft. So the end caps on the new drive shaft along with the body of the new u joint are two big. can any one suggest a u joint with a small body and big end caps?
10-15-2009 #2The drive shaft that you picked up probably has the newer 3R u joints and the 9 inch probably has a 1310 yoke. Your old drive shaft also should have the 1310 u joints.
'69 RS/SS396 pro street/427/4spd/9"
http://rides.webshots.com/album/576443881hfGXxd
http://good-times.webshots.com/album/568860081GZRpyZ
10-15-2009 #3
- Aug 2008
- 167
Yes sir, so I needed a 1310 to 1330 conversion u joint. thanks for your help though.
