    Results 1 to 20 of 20
      CT
      Is this guy for real?
      I was searching ebay for stuff and found this guy selling a rotisserie.
      http://cgi.ebay.com/ebaymotors/1969-...Q5fAccessories
      Is this thing really made out of WOOD??
      IL
      WOW Yes WOOD Here's your sign
      Rick
      May 2002
      Northern California
      well they did build the pyramids with wood supports structures. LOL
      vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      They have been making trees out of wood for years -- it's good stuff.
      Cumberland, Maryland
      Your house is likely made out out of wood. It comes down to the construction technique, not the material. Their is no reason you couldn't safely build such from wood.
      Bay Area
      I think he is a member here or over at Lat-G.
      Jose (Joe)
      1963 Nova SS Convertible
      1978 Malibu LT1/4L60E
      1978 Malibu Stock
      2007 Harley Dyna SB
      Wood = no problem.. Charging $300 for $40 worth of it= problem..
      Aug 2006
      Easton, PA
      Quote Originally Posted by LowBuckX View Post
      if it is well engineered, he did all the homework for you. that's worth something. and it has all the hardware, so, it 'might' be worth $300.
      although, anyone that builds cars, should be able to design a wood rotisserie also.
      Keith C.
      Quote Originally Posted by twosaturns View Post
      my point exactly
      Fife, WA
      We've got a whole stack of pallets, uh I mean rotisseries, alongside the building - I tell you what I'll sell 'em cheap!
      Crown Point, Indiana
      I made mine out of wood. Dont know that I would sell it on Ebay.
      Wood is an engineering material- it has repeatable mechanical properties that can be used for calculation.
      Early aircraft were made of wood. The dehavilland Misquito fighter/bomber from WWII was aircraft plywood. Frank Costin, who worked there in the late 40's/early 50's designed the Marcos, Nathan sports racer, and Amigo using plywood torque boxes attached to each other with glue and nails for the car's chassis.
      No reason a wood rotis. won't work.
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      SF bay area, CA
      It looks like two pallets stood up on end and are not even attached to each other. I'm sure it works but it looks a bit scary to me.
      Tim's on the other hand at least looks like it's worth $300.
      Rustburg, Virginia
      Looks like it "wood" do the job....
      Houston, Tx
      Looks like some wood and some steel. I think I'll do something similar when that time comes.
      Here's a car made of wood! Home page: http://www.joeharmondesign.com/index.html
      Boston MA
      Quote Originally Posted by Ron L View Post
      PT 4X4s and 2X6 look like pallets to you? What's the deck on your house look like? Wouldn't hesitate to use that rotisserie. WAY cheaper that building it your self out of steel.
      1967 #s RS
      Damn that looks good... are those 4x4s 0r 6x6s
      Quote Originally Posted by GRNOVA View Post
      Atlanta GA
      SF bay area, CA
      Quote Originally Posted by wendell View Post
      Yes they look like pallets, no triangulation whatsoever. Properly designed you could build it stronger and with less wood, like Tim's. Like I said I'm sure it works though, it's not like we're building 2-post vehicle lifts out of wood. A stripped-out body shell isn't really that heavy.
      Thanks Ron L, I used 4x4's for the uprights 2x4's for the braces, through bolted at intersections 1/2" nut and bolts and 1 5/8" steel tube and 2x2" square tube for Bumper mounts. Then to connect them I used two 2x4's. All for less than $150.00. Financially challenged collage student 17 years ago.
