    Results 1 to 20 of 29
      Orlando, Fl
      Trunk mount battery - Definitive thread on safety/legality
      So after doing some searching on here, I have yet to paint a super clear picture of what is and what isn't appropriate when moving a battery out back.
      I would like to be able to do this once and do it right. I am certain that once my car is complete, I will definitely sign up for some HPDE's, a little autocross, open track days, etc...
      So I am tapping into the collective knowledge of Pro touring.
      So here are the questions...
      For starters, when running an optima, is a battery box required? Is a firewall needed between the passenger compartment and trunk?
      How about external kill switches? Are they required?
      I most likely will run MAD Electricals remote solenoid. From there, I don't know. Want to stick the battery right underneath the package tray, offset to the right/passenger side.
      Any help and info, feel free to add it.
      Nick DiPrenda
      Rockford Illinois
      With the cost of the Braille batteries vs optima and the weight difference vs performance, I would seriously consider losing a litle weight and size and get the Braille. So far everyone that has one they bought from the HotRod Shop where I got mine has really been happy.
      Hooking in a kill switch is always a thing to consider when doing all of this.
      The choices are up to you as there are lots of ways to do it. But the battery is needed no matter what so you might as well spend $30 more if that and get the best and more.
      Either the Braille or the optima can be mounted in any position and in most all places without a battery box.
      Orlando, Fl
      Quote Originally Posted by Jim Nilsen View Post
      Dammit man... Why did you have to bring up Braille... I have contemplated switching to a Braille battery for a while. I already have a yellow top Optima, but may make the switch. That yellow top is a boat anchor. Which size Braille would you recommend?
      Nick DiPrenda
      Newbury Park, CA
      For me adding the switch was a no-brainer. It allows disabling of system power for servicing the car, acts as a theft deterrent, and is a major safety item allowing shutdown in case of electrical problems. It can be mounted inside of the trunk for stealth with a removable plunger that is external to the body.
      For HPDE the battery needs to be securely mounted. I use a bracket from Speedway that works just fine and there has never been a problem from the host organizations. No other firewall besides what the factory offered was needed. There may be additional NHRA regulations that you may want to consider if you fall into the requisite category(s).
      The Camaro has a small auxiliary power panel in the trunk. It has a 3A bypass for the ECM and various memories to stay intact, a breaker for the fuel pump, and another for the amplifier. Since it only ties into the battery bracket there are no additional holes drilled in the body. I'm working on an external handle/plunger that will route through a bumper bracket bolt hole that will allow turning the switch off with the trunk closed (NHRA).
      Thats a nice setup Carl . What size (Amp)switch did you use ?
      Newbury Park, CA
      It's just the standard trunk mounted on/off switch offered through various distributors. My friend John gave it to me since he thought it was bad, but it was fine. Free is good!
      Florida
      Does that turn the engine off Carl or just the battery? I've had trunk mounts before with a battery shutoff external mount but tech requires engine shutoff to be correct. I want to move the battery in my Firebird and want it correct this time.
      Rockford Illinois
      Quote Originally Posted by dipren443 View Post
      Dammit man... Why did you have to bring up Braille... I have contemplated switching to a Braille battery for a while. I already have a yellow top optima, but may make the switch. That yellow top is a boat anchor. Which size Braille would you recommend?
      I have the B3121 which fit in place of my Odessey. It weighs 21 lb. and is 6.8 x 5.8 or so and has terminals that can mount top and side. For $190 tax included it has it's advantages.
      Really think this out before you do it. Flaming River makes a kill switch that is a push to kill instead of turn and can be set up in a lot of creative ways to enhance the theft and saftey of the car.
      Bay Area, Cali
      Im in the same boat. I have a shutoff switch I got for free that has 2 posts, kind of like this http://www.summitracing.com/parts/TAY-1032
      Im pretty sure that the car will still run if I only wire it to the battery. Can I run the alternator wire to the trunk and back so I can run it in with the battery? Or would that blow something up...I'm not very good with wiring.
      Orlando, Fl
      Really think this out before you do it. Flaming Riover makes akill switch that is a push to kill instead of turn and can be set up in a lot of creative ways to enhance the theft and saftey of the car.
      Jim,
      I have all winter to do this. That is precisely why I posted this, I most definitely want to do this right. I HATE doing things twice.
      This the one you are talking about?
      Nick DiPrenda
      Newbury Park, CA
      It only kills power to the battery. However, since the fuel pump power is wired directly from the main switch, and if the 3A bypass is disabled, turning off the main switch will also turn off the power to the fuel pump.
      Rockford Illinois
      Jim,
      Yes it is.
      Rockford Illinois
      Quote Originally Posted by Burnout1121 View Post
      If you run the wire from your alernator to your battery instead of to your starter and put the kill switch between the positive cable and the rest of the car, the alternator cannot give power to the car once the switch is turned off.
      The Flaming River kill switch has terminals that will kill the power to the field on the alternator if needed.
      I have a one wire alternator and this setup works good to kill the car.
      There are so many ways to wire this kind of system up and the biggest hurdle is the wiring harness you may already have and how to make it work as a system without running another mile of wire to do it.
      Southern Indiana
      i used a painless master switch, and used it to cut the battery ground,,,, killed car instantly.
      I simply had my 8ga alt wire ran to solenoid on fierwall,made my own starter jumper and ran a 2/0 from solenoid to starter I had double insulated 2/0 from hatch mounted battery to solenoid and also used piece of heater hose and some split loom and a hole grommet for battery positive cable through firewall to solenoid.
      if you cut all grounds (except memory items) car will die.
      My ground was 2/0 from batt neg to switch , then switch to clean chassis ground. also added several ground from block to chassis(unibody as it was a 77 Monza) if you interrupt positive,the alt can still make circuit to ign,killing negative and no complete circuit.
      Rockford Illinois
      Some tech rules do not allow the ground to be used to break the circuit because in an accident torn wiring can make the ground in their eyes. I have never believed it would ever make a sufficient ground but I didn't write the rules and MAD enterprises has fought with the NHRA over it a long time ago. It really does work and is a lot easier to wire that way but the reason for the fancy solenoid from MAD was to make it all work according to the rules.
      The Flaming River switch if installed in the rear of the car might actually kill everything in a rear impact as it is a push button and not a rotating switch.
      Oct 2006
      Morristown, NJ
      Jim is correct. You can not use a negative disconnect to shut down the car. I used the heavy duty summit switch. I wish I had purchased a switch with dual terminals that would shut down the main power as well as the alternator.
      1973 Camaro Type LT/RS
      http://www.apiem.com/camaro
      Melbourne, FL
      Double check your specific tech specs on cutgoff switches. I'm pretty sure some, NHRA, require a PUSH type kill switch only to be used and must also kill the motor.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Oct 2006
      Morristown, NJ
      The following are from the 2008 NHRA Rulebook:
      8:1 batteries
      All batteries must be securely mounted. Must be of sufficient
      capacity to start vehicle at any time. Batteries may not be relocated
      into the driver or passenger compartments. Rear firewall of .024-
      inch steel or .032-inch aluminum (including package tray) required
      when battery is relocated in trunk. In lieu of rear firewall, battery
      may be located in a sealed .024-inch-steel, .032-inch-aluminum, or
      NHRA-accepted poly box. If sealed box is used in lieu of rear
      firewall, box may not be used to secure battery and must be
      vented outside of body. Relocated battery(s) must be fastened to
      frame or frame structure with a minimum of two 3/8-inch-diameter
      bolts. (“J” hooks prohibited or must have open end welded shut.)
      OEM-located batteries without complete OEM hold-down hardware
      must be secured to OEM battery box/tray using the same 3/8-inchdiameter-
      bolt hold-down method described in previous sentence.
      Metal battery hold-down straps mandatory. Strapping tape
      prohibited
      8:4 MASTER CUTOFF
      Mandatory when battery is relocated or on any vehicle running
      9.99 or quicker. An electrical power cutoff switch (one only) must
      be installed on the rearmost part of each vehicle and be easily
      accessible from outside the car body. This cutoff switch must be
      connected to the positive side of the electrical system and must
      stop all electrical functions, including magneto ignition. The off
      position must be clearly indicated with the word “OFF.” If switch is
      “push/pull” type, “push” must be the action for shutting off the
      electrical system, “pull” to turn it on. Any rods or cables used to
      activate the switch must be minimum 1/8-inch diameter. Plastic or
      keyed switches prohibited
      Hope this helps
      Dunwoody, GA
      does SCCA require a positive side kill switch or will one on the ground be acceptible?
      I didn't even think to include a kill switch with my design. I did however not keep the 2/0 starter feed live 100% of the time. I have a 6ga wire off the alt for that but it has a circuit breaker on it for safety.
      Trey
      ~ Jon Hammond
      Melbourne, FL
      What I plan to do with my cut off switch is to have two different tail light housings. One for street and one for the track. The track one will have a hole in it for the cut off switch rod to pass through. This way it's legal for the track but no one will be able to disable my car when driving it on the street. Just my .02.
