    Results 1 to 18 of 18
      rainy ass NW
      why am i tilted?
      doin some quick mods jus to get da beast on da road.
      i cut my coils jus to drop em down, QA1 stocker shocks all roun'
      jus got it on da ground, an da bugga tilts an inch to the pass. side
      i cut 1 coil, even on both... if it was tilted i never noticed til now.
      *meassured to da lower lip a da fender*
      <--front
      LH 24 3/4-24 1/4
      RH 23 5/8-22 3/4
      i love da look of da rear pass tire, obvi. da lowest...
      equal tire pressures..... thinkin of jus gettin the hotchkis 2'' drop springs but affraid i'l have da same prob.
      why am i tilted? tanks bruddahs!
      '69 Figherbird
      beauty's not in the budget
      Check you rear springs. One rear spring could be weaker than the other causing the uneven frontend.
      This "assumes" that the front springs you cut were new high quality springs and NOT old probably worn out springs that may match the back springs.
      Mike
      www.musclecardeals.com
      IL/TN
      Number of coils is not a unit of measurment so your springs may not be equal length after cutting
      https://www.protouringf-body.com "doing what they say can't be done"
      rainy ass NW
      old worn coils...
      ordering hotch springs today
      we'll see
      '69 Figherbird
      Jun 2009
      Avon, IN
      learning how to type would also help
      Oct 2008
      Kingsland, GA
      Quote Originally Posted by 70IndyChevelle View Post
      He is typing how he talks.
      Aaah, Hawaii... the most racist state in the union.
      Your problem is you cut your springs. You went at something with an unscientific approach, and expect specific results.
      Feb 2008
      Nothing wrong with cutting springs - racers have been doing it for years. Keep in mind that you will increase the spring rate when doing it.
      Matt Barr.
      rainy ass NW
      hawaiian style cuz, spam musubi's brake da mout! if u never been to da islands look for em!!
      hotch's should come THE:bsjerk: (haha na na na),next couple of days, ordered for good reasons den. anyone one runnin them with a better front end setup den stock, like the feel?
      jus tryin to get a good stance so i can drive em, get a sense of what it 'was' before i really start buildin
      its been sittin awhile, im stoked with jus drivin it for meow
      '69 Figherbird
      florida
      Just so you know the Hotchkis springs will probably make your car sit higher than it did with the uncut springs...
      Oct 2008
      Kingsland, GA
      Try this -
      Get some 2x4's stacked up to where you want your ride height. Take a propane torch to your springs until the car sits on the 2x4's. Let it sit for about a day, then lift the car and pull the 2x4's.
      This is slightly better than cutting your springs. At least it gives you an exact result.
      rainy ass NW
      wtf. why call em 2" drops... at least you said probably, i hope it turns out the way i've pictured it........
      i've heard its not a good idea to heat up springs exactly like that, so i opted not and cut em
      '69 Figherbird
      Oct 2008
      Kingsland, GA
      Quote Originally Posted by ProTour69Bird View Post
      It is also not so great an idea to cut springs, but you already did that lol. You're doing it for looks, and not ride quality... you might as well go all the way with it.
      Fontana, CA
      Quote Originally Posted by DoABarrelRoll View Post
      Try this -
      WORST way to lower a car EVER! And there is nothing exact about it.
      Nick R.
      Oct 2008
      Kingsland, GA
      Quote Originally Posted by 6'9"Witha69 View Post
      scientific proof?
      Fontana, CA
      Experience, and lots of it. I would like to see scientific proof that says application of heat at potentially varying intervals, concentrations and locations from one side to the next is accurate or scientific. BUT, when 2 springs of equal height and rate are cut by equal amounts, an equal outcome will occur. Much moire scientific than the eyeball gauge of thermodynamic and metallurgic impact.
      Where's your tech?
      99 times out of 100, any difference side to side is a bent frame, improperly indexed springs, bushings binding inconsistently from one side to the other, etc. The 100th of 100 is the springs are inconsistent in height or rate. Using a torch and heating the springs (which actually can soften the ride due to a decrease in spring rate, there is science around that) to get thing level is merely a band aid over what could be a very simple or serious problem.
      Nick R.
      IL/TN
      Try this -
      heating up the spring will aneal the steel (soften it) casing the wire to bend and not return to it original shape and you will cause soft and hard spots along the length of the spring and this could cause the spring to break, so it's the WORST thing to do
      Nov 2002
      state of confusion
      Quote Originally Posted by 79T/Aman View Post
      Seen it happen. Even when it happens inside a pigtailed end coil, it's still scary.
      I'm afraid that I have absolutely no idea what you just wrote. If this was a face to face discussion, I would ask you to please try again or explain in more detail.
      In order to have any chance of getting the right answer, the question must first be understood by the person trying to provide that answer.
      Not intended as flame.
      Norm
      Gone but not forgotten dep't:
      Quote Originally Posted by Norm
      Spot on. ProTour, we expect folks to attempt to write in English, and we also expect folks to have a name in the signature (a first name is sufficient). Anonymous posts in "stylized" English will likely not get you the results you're looking for. You are asking technical questions, and looking for technical answers. The burden to provide information is on you, and English is the expected method.
      As for heating springs: it's a bad idea. That's well established, and requires no further justification.
      jp
      ​John Parsons
