    Results 1 to 20 of 30
    Thread: LS3 Accessories
      Dec 2008
      LS3 Accessories
      Just picked up an LS3 without any accessories bolted on. The enegine will be going into a 69 Camaro...big surprise, right.
      Need to know what location is needed (best) for the Alternator and a good source to order everything in one shot. This would include all pulleys, water pump, harmonic balancer power steering pump, etc
      Thanks for the help.
      May 2008
      Staten Island, New York
      I left most of my accessories in the stock locations with stock pulleys except for the AC compressor.
      http://www.crateenginedepot.com/stor...7-P1735C0.aspx
      http://hotrodlane.cc/
      So Cal
      I bought the same GM P/N 19155067 C6 Corvette accessory package linked in the above post for my LS3 crate engine, but I bought it for a lower price here: http://www.sdparts.com/product/19155067/ACSRYDRV.aspx
      You'll also have to buy the correct damper (harmonic balancer) so the belts will line up (P/N 12620556) as it doesn't come with the accessory drive kit. My LS3 crate engine already had the correct damper on it since it's a C6 Corvette replacement engine.
      To move the A/C compressor to a better and more serviceable location and at the same time avoid notching the front crossmember to make it fit I bought these A/C compressor relocation brackets:
      http://www.kwikperf.com/lsx_ac.html
      Keep in mind that you're expected to use a Sanden compressor instead of the one from GM. You'll also need a single serpentine belt that is used instead of the two belts supplied in the GM accessory drive setup, Gates P/N K061010 (13/16" X 101-5/8").
      Bart F.
      '64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
      '64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
      '02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
      May 2008
      Quote Originally Posted by b-man View Post
      This is the same bracket that I used on mine.
      Jun 2005
      Greenwood, SC
      Another alternative, if you're willing to notch the frame, is f-body components--at least, I think these still work on ls3's?
      Not positive as I went with the corvette setup, even though f-body setups are a very-tight-fight-but-no-notching sort of deal on 2nd gens.
      (another angle on the corvette setup, to give you an idea of how it looks in a car) (ok maybe I just wanted to show it off a little)
      Aug 2003
      My favorite LS set up is Wegner. They are more money then the GMPP stuff, but are engineered for high RPMs and great clearance of all subframes. We have them ready to ship
      Walla Walla, WA
      This is pretty much the route I'm taking, except I ordered the accessory kit without air because I was replacing the AC bracket and compressor. The accessory kit without air is around $500 or so.
      So Cal
      Quote Originally Posted by Mkelcy View Post
      I wish I'd have gone that route, now I have a compressor, bracket, tensioner and 2 belts that I can't use.
      Live and learn.
      Jun 2005
      Greenwood, SC
      Quote Originally Posted by ProdigyCustoms View Post
      hot damn! that looks awesome.
      Dec 2008
      Thank You all for responding.
      Frank, What's your kit going for? Minus the A/C set-up. I'm not planning on running A/C in the car.
      Forgot to ask about the correct style of Oil Pan to purchase as wel.
      Hows this one?
      http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
      So Cal
      I chose the Autokraft pan, also sold under another brand name that I can't recall. It's priced at $399.95 right now.
      It fits along with the Edelbrock engine mount adapter plates and headers I'm using.
      Made for the '64 -72 A-body cars and '67 -'69 F-body cars and doesn't require the use of a remote oil filter if that matters to you.
      http://www.autokraft.org/products/
      Aug 2005
      Hamilton, NJ
      How is that compared to the VA front runner setup?
      Scott from NJ.
      Vent Windows Forever! ...
      Dec 2008
      Frank,
      Can I get a price quote on this package?
      Thanks Marc
      Dec 2008
      Ttt
      bowling green,ky
      serp system
      will a balancer w/ part number 594271 which i am told is a corvette ls1, ls6 part go with the gm serpentine accessory drive part number#19155167 which is a corvette style system w/out air. i am using the vintage air bracket.
      Dec 2008
      Frank,
      Hoping to hear back on a price for that Wegner set-up.
      Thanks Marc
      Aug 2003
      The Alternator / PS system with no A/C is $1550
      Aug 2003
      Quote Originally Posted by BonzoHansen View Post
      The Vintage Air set up is a awesome kit. I think the Wegner Kit is a better high RPM unit.
      We sell both.
      Aug 2005
      Hamilton, NJ
      Thanks Frank.
      What defines 'high RPM' - over 7000? 6500+? Prolonged use over 5000? Just curious.
      Scott from NJ.
      Aug 2003
      In Wegners world high RPM is 8000+ but even for use to 6500 which is easy to do these are the best out there. WAlthough, I know the VA units run to 7000 quite often so by no means am I saying they wont take RPMS
      Personally for the price and looks, I prefer the Wegner
