    Results 21 to 40 of 59
    1. #21
      St.Anne Il
      looking killer..i need to get down that way to check it out before sema ..im not to far from ya..awesome work ya do..
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
    2. #22
      Aug 2008
      KCMO/LOTO
      Can't wait to see this complete John! I grew up in Pontiac most my life watching your many different builds! Keep up the good work!
    3. #23
      Flanagan IL.
      Thanks I will post some more pics tomorrow. I only have about 18 days left so it will be tight. I also have a Cadillac Escalade project to finish in the same time frame. Later
    4. #24
      Flanagan IL.
      latest update
      Today went well. installed the Firestone air bags. upper and lower control arms, new spindles. installed the front and rear Disc brake kit... new ball joint,bearings, tierods, ect.
      also got the Painless Performance wire harness laid out. this is a complete body and engine harness for the LS1 motor and 4L65E trans.and all of the body wires as well. it is a pretty cool idea seem to be laying out nicely. mounted the fuse panel underthe dash. In stalled the Lokar black shifter on the trans and the pedal inside. need to locate the shifter and cut a hole in the floor next.
      I figured I better take a few pics of me doing the work I didn't want you to think I had a Magic stick or something. LOL I'll keep you posted.
    5. #25
      Flanagan IL.
      Well the Motor got drop in today. Yea Ha. The Hooker LS1 Motor mount and headers fit great. you can see in the pics there is a good amount of clearance all over. I got the Firestone Compressor installed in the trunk, and the rear deck covered in caron fiber mat. the Sony 6 1/2" sep. and tweeters mounted and wired up. working on the trans mount tomorrow and wiring motor.
    6. #26
      Aug 2008
      KCMO/LOTO
      Sweet! Coming along quick!
    7. #27
      Apr 2007
      Utah
      Wow, that is cool. I see you went to length to color code the tape you use for the build too. Looking great
      Sam
      Northern UT.
      '68 Camaro "Bodacious"
      '56 210 2dr "Buckshot"
    8. #28
      Flanagan IL.
      I just finished Painting the Lime Time Camaro.
      Lamborghini Green base, with chacoal stripes, added some pinstripes around the strips, then Pearl flip flop tricoat over everything. added a little airbrushed fender vent just to spice it up. Finished it up with 4 coats of Clear coat. all done in PPG products. I used a Orange pinstripe color. the first up close pics really show off what the coor looks like. the other pics faded out whenI took the pic. Hope you all like it. It will take a little buffing tomorrow then finish putting it together.
      I also got the Kwik Performance accessory brackets installed befor I took it into the booth. These are really nice bracket for anyone looking install was a breeze. as easy as a stock setup. I will add a coupe pics of that tomorrow.
    9. #29
      BROOKLYN .NY
      Country Flag: Puerto Rico
      awesome color's
    10. #30
      Flanagan IL.
      Here is the first pics with the Car on the ground with the TSW wheels and BFG tires. The detail pics show off the Pearl I used it really make the Green sharp, it has a blue,green yellow red flip to it.
      Covered the dash with Carbon fiber mat today. Installed the sub box with a pair of SONY subs and a Sony Amplifier, in the trunk.Kinetik battery in the trunk. Mounted the rear spoiler. more tomorrow.
    11. #31
      Oct 2008
      Roseville
      Sunlight pics needed!!!
    12. #32
      Sandy, OR
      Quote Originally Posted by camaro2nv View Post
      X2
    13. #33
      Sydney, Australia
      Country Flag: Australia
      Wow!
    14. #34
      Love the front fender detail,, very nicely done...
    15. #35
      League City, TX
      Project KeyLime :D
      John Brown
      1971 Nova - Project Car
      1990 Silverado - Ridetech StreetGRIP
      Instagram @wilwaxu
      Facebook @wilwaxu
    16. #36
      Flanagan IL.
      We have the trunk almost finish, 2 Sony 10" subs, and Sony amp, NOS bottle, compressor from Firestone, Carbon fiber covered panels. Tail light installed, headlights installed all wiring done to them, adding driving lights where the hole in the grill are. Turn signals are in the headlights. brake boost installed, running brake line Classic tubing stainless steel, now and the fuel line is from Tube Tech. rad. hoses are on and the Classic auto air kit is finished up as well.
      The Kwik Performance brackets fit perfect. I used the Corvette version so it gave me a little more room betwen the engine and rad. Radiator is from Mark 7 radiators. they made it to specs I asked for and bolted right up. They even offer black anodizing but I did not have time to wait the extra 2 weeks. Spal dual 11" fans are installed and wired to the painless harness, I did have to get a Speartech 4l60e to 4l80e conversion wire kit. Lokar shifter is installed, with the boot having the indicator on it. i used all of the Midnight series so the pedals and the shifter plate are Black anodized, look sweet.
      got all of the Steel Rubber seals installed.
      7 days till we leave!!! it gonna be close but we should make it.
    17. #37
      Jul 2009
      Grand Rapids, MI
      Looking real good. What kind of headlights are those and what are you using for driving lights?
      Will Ellis
      Build Thread
    18. #38
      Flanagan IL.
      The headlight are black out lights from APC and the driving light are called 6 shooter from apc as well. they took a small amount of trimming to get them to fit but the headlight have the turn sgnal inside them so I was able to use the turn signal hole for the drving lights. I got the Magna flow stainless exhaust on today, Finished the Tube Teck stainless fuel lines, finished the Classic tubing stainless brake lines. Installed the ecm today. I hope to install the other Kinetik battery in the front and work on the Power steering lines and res. tonight after supper. Mabee fire it up Tomorrow. I hope!!!!
    19. #39
      St.Anne Il
      looking killer ..but with all the rain here lately dont think you will get to drive it any time soon ..not around IL that is..lol..can't wait to see it finished Killer work !!
      Darrin Stalnecker
      1968 Camaro LS1 T56
    20. #40
      Jul 2009
      Grand Rapids, MI
      Thanks for the info on the lights. I'm thinking of doing something very similar. I can't find anything on these lights though, might you have a link to them somewhere? Thanks.
      Will Ellis
      Build Thread
