      Sep 2007
      Michigan
      I've been using a new brass fitting every time. In fact I tightened the first one to the point where it bottomed out and started leaking like a stuck pig. I have not tried pipe dope but I did use liquid teflon for the first one. I don't think that had enough time to set and was actually eaten away by the brake fluid. I'll try pipe dope next. I'm open to any suggestions so thank you.
      here is the description from baer-
      Acurately adjust front to rear brake bias with this adjustable proportioning valve from Baer Brakes.
      The prop valve body uses 1/8 pipe thread (NPT) and the adaptors we supply with this are 3/8"-24 tube nut for 3/16" tubing and 7/16"-24 tube nut for 1/4" tubing.
      Keep em coming.
      Marcus K.
      LS7 w/Twin Precision 6266s, Viper T56, 4 link suspension, ATS spindles, Kore3 conversion.
