    Results 1 to 14 of 14
      Oct 2007
      ATS motor plates and AutoKraft pan?
      Hi Anyone know if the autokraft pan works with the ATS plates?
      http://www.autokraft.org/products/
      I purchased the plates already and was wondering if anyone has already run these plates and this pan.
      67 Camaro In progress
      Mountain Springs, Texas
      My understanding is that it works. I recall Tyler stating it somewhere. You just have to tap an extra mounting hole in the block or it will likely leak.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Oct 2007
      sorry Don I am not following
      May 2002
      Southeastern WI
      I have the ATS plates with a Champ pan, which I suspect, but have not verified is identical to the Autokraft pan. Depending on which frame mounts you use the pan will clear a stock subframe. I think I ended up with the stock small block frame motor mounts. The 302 mounts were too low and the pan hit the subframe.
      Jeff
      Quote Originally Posted by XLexusTech View Post
      The Autokraft pan will likely leak if you do not tap an extra hole in the block when it is installed. Nothing to do with the ATS mounts. Sorry for the confusion.
      Don
      So Cal
      Any idea where that extra hole needs to be added?
      I wonder why Autokraft would not include this little added tidbit of info for the proper leak-free use of their pan?
      Bart F.
      '64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
      '64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
      '02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Quote Originally Posted by Van B View Post
      Champ pan = Autokraft pan
      Quote Originally Posted by b-man View Post
      You will see a mounting hole in the pan without a corresponding hole in the block. At least that is my understanding.
      Don
      So Cal
      Don
      When I put my Autokraft pan on my new LS3 crate engine there were no extra bolt holes in the pan that were unused, all of the bolt holes lined up with the same ones used by the factory pan.
      https://www.pro-touring.com/forum/sh...ight=autokraft
      So Cal
      This might be a problem with LS1 blocks only, on my LS3 it bolted up with no 'missing bolt' issue.
      Too bad there are no pics in that thread to show where the missing bolt hole is.
      Oct 2007
      LS3 for me too. Thanks all!
      Country Flag: China
      Autokraft pan went right on my LS2 crate engine with no extra bolt holes either . . .
      May 2009
      Iowa
      Autokraft pan right on GMPP LSX block, have there engine mounts too, clears everything great
