      Calgary, Alberta
      Rear suspension attachment ??
      I'm in the process of swapping out the stock rear end in my 69 Firebird for a new Moser 12 bolt. The original one was mounted using a single "U" bolt in the outboard position and 2 "T" head bolts on the inboard ones.
      I intend to use new parts, but was wondering if I should use the "U" bolts in both positions, or replicate the stock system of attaching the rear end to the springs.
      Thoughts? Opinions?
      Cheers,
      Ken
      Loganville, GA
      Use two u-bolts per side, forget the t-bolts. GM probably did that to save $$$$.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Calgary, Alberta
      Will do. Thanks so much!
      Hotchkis provided 5/8 u bolts with their leafs. I like mine and if you look at the 4x4 manufacturers at Summit you can find these also...
      u bolts are as close as your local auto parts store. the stock mounting plates are drilled for 7/16", i think (which is plenty strong) but 1/2" or even 9/16" are an easy upgrade with only a quick pass thru each hole with the appropriate drill bit.
      IL/TN
      stock was 7/16", just upgrade to 1/2" U-bolts, drill out the holes to 9/16" this will make assembly much easier, uni-bits/step drill bits are great for opening holes to the next size
      https://www.protouringf-body.com "doing what they say can't be done"
