Results 1 to 11 of 11
Thread: Intercool vs Methyl injection
08-27-2009 #1
I've been considering boosting my engine and after looking into different superchargers and turbos I feel the best option for my current setup is a twin turbo system.
I've talked with the owner of the shop that did my F.A.S.T tuning and who also is big into custom turbo and pro-charger systems since he is familiar with my drivetrain setup and he recommends the injection over the intercooler.
His argument is that the size of the intercooler needed to sufficiently cool the charge air would create more work and cost more than then the gains are worth. As well as the location would inhibit engine cooling by restricting cool air from entering the radiator and also replacing the cooler air with heated air from the intercooler.
His argument for the Methyl inkection is that even though it cools the incoming air charge an additional benefit is that it also raises the octane rating of the combustion mix.
I have not been able to find much information regarding the injection and am looking for opinions on it. I know that intercooling is the most popular but are the gains really worth the expense and extra plumbing?
1986 Monte SS, 427 sbc, Victor E manifold, FAST TB, FAST XFI, T56 6spd, Moser M9 rear 3:70, SC&C G5, Spohn lowers, Pole Position Uppers, Alston Coil Overs, Pirelli all around
08-29-2009 #2This would TOTALLY depend on what type of TT or SC you are running, objectives and tunes. I have WM with my twin screw SC and also maybe buying another 1550-1600 RWHP TT WM street Viper this weekend. Even the WM can be water, WW fluid, 50-50 and a myriad of other combos. I use 11.5-12.0 AF with WW fluid on 10 lbs of boost and have 22K miles of hard street driving on the combo and I tune my own cars, but this subject is like the Ford verses Chevy arguement. Honestly, it will depend upon a LOT of things and you can run both, and hell even NOS on top of that. I am going to be pushing spray into two of my cars now and SC/TT cars LOVE spray more than NA motors. Anyhow, this is a huge topic, but like this post, it will help you to begin to learn more. Check the guys that are running SC and TT's that you are running on engine wise and ask a lot of questions and listen is my best suggestion. Gary
1968 GTO 467 ported Pontiwreck, 9", 5-Speed
2000 Viper GTS, 10Lb SC, Roller Cam, Fully Ported
2008 Viper SRT-10 Coupe, Stock, FOR SALE
2008 Grand Cherokee, 3" OME Lift, armor/winched
2006 Votes thanks to Acorn
08-29-2009 #3
Starting The Transformation
- Jun 2005
- 467
For a street car that's driven any distance, I consider a properly set up intercooler to be the cake, and meth injection is the frosting. The IC gets your temps down into the sane region and the meth is an insurance policy for hot days, dyno days, drag days and the chance of a poor tank of premium.
You have a lot of space in that Monte nose, so if you lay things out correctly you can have your turbo setup, a large IC with great airflow to/from, and a radiator that easily keeps up with the demands you will place on it.
What kind of power levels are you targeting?
Check out my site for another G-body with a large (2074cfm) IC and an FJO Racing meth kit on its way in now (you can see the solenoid mounted on the right side of the air hat in the front-on engine shot):
http://home.mindspring.com/~jim_fisk/id1.html
I have no problems with water temps.
JimDon't take a knife to a gunfight.
Half-Assed = Half-Fast
09-01-2009 #4Thanks Guys,
DeltaT since my engine is at 10:3 compression and I do not plan on changing any internals I was planning on keeping things reasonable @ 8-10 lbs of boost. I figure this should net me about 200hp at the rear wheels.
SInce I am already running a 4 core Aluminum radiator and aluminum heads I'm confident that my engine cooling is sufficient. And although there is a lot of room in the Monte;s nose I think that the available airflow helps keeping things cool and restricting that airflow (IC) may be detrimental.
Lemme go look at the link you posted, that may help me out some.
Thanks.
09-04-2009 #5
