      May 2006
      Orlando
      first gen with 1 wire alternator
      with the exception of electric fans and a vintage air kit my electrical system is mostly stock right now. I'd like to add a 100amp 1-wire self regulating alternator with upgraded alt wires. I don't understand what happens with the stock voltage regulator or more specifically all the wires feeding from it.
      david
      68 camaro 350 SS convertible ala prodigy customs
      - its as much about the journey as it is the destination
      Oklahoma
      redhead,
      I almost went the same lway your headed with my first generation camaro. I did some research and found a better charging system. Mark at madelectrical has a good write up that explains both system and the advantages and disadvantages of both. Here is a link to madelectrical: http://www.madelectrical.com/electri...hreewire.shtml.
      I would recomend going with the three wire, not hard at all to wire up.
      Jason
      May 2006
      Orlando
      thats good info and reason for me to second guess my 1 wire selection
      (thanks a lot . regardless of the 1 vs. 3 wire debate my question
      should have really been: with an upgrade to a self regulating alt
      what is the correct way to rewire once the divorced voltage regulator is removed?
      com'on fellas I know lots of you have done this.
      david
      Long Beach CA
      I thought the one wire thing was the way to go. Even put a larger cable from the alternator to the battery..thought I was cool! I am now going to change to the "MAD" way...makes a lot of sense. They have schematics on the website listed, and have some nice technical articles into why and how. My 105 amp alternator has never shown more than 12ish volts. Re-read the article and get your wiring back to what was done stock. It looks like they use the stock regulator. Read this section here
      http://www.madelectrical.com/electri...reewire3.shtml
      buy their book, then call and ask questions...these guys make sense!
      Fontana, CA
      The thick red wire to the regulator from the "junction" is eliminated, the brown and blue (don't quote me here) are linked together and another is eliminated by taking the remote sensing wire from the regulator to the horn relay bus bar.
      I would talk to Mark @ MAD. The kits for using either a SI or CS alt come with detailed instructions.
      While you are at it, read the tech sections and look into the brighter headlights. You won't regret that upgrade either, especially at night and 'everything' is turned on.
      Nick R.
