      livermore ca
      primering when jams are painted
      i need to shoot the car in primer one more time, whats the best way to tape the car off when the jams are already in color? overlap the primer on the color and then just wet sand it or leave 1in between the paint and primer?
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
      Phoenix
      A cool trick a lot of painters use to avoid a hard edge is to fold the edge of the masking tape over (but leave some adhesive exposed obviously) so when it's stuck on it has kind of a flap facing towards the surface being painted. As you're spraying some of the paint flows under the flap but no hard paint edge is formed. I had my jambs painted first then masked this way and then assembled the car and painted the exterior. You cannot tell the jambs were painted before the rest of the car.
      TN
      Thats how we do it at the body shop where I work.
      Benjamin
      Twin Dusters
      Feb 2003
      St. Louis, Missouri
      I've always called it "back-masking" and 9 times out of 10 you can still make out where the line is; whether it's a crisp tape line or dry spray. Best is to recolor and clear the jams with final paint. JMO.
      Rick Butterfield
