    Results 1 to 20 of 21
      Windham, NH
      Ford 9" Rear Axle Vent
      Anyone use this vent from Summit...?
      Phil
      Build site: www.73camarobuild.com
      Business: www.classiccarblasting.com
      Like us on Facebook!
      Oct 2006
      Phoenix, AZ
      Cool, so that threads in where the fill plug does? I'll be curious to see what people have to say.
      Jeff K.
      69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
      Think it goe into a vent port on the top of an axle tube.
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Windham, NH
      Correct. Mine is 1/8" some are 1/4"
      Phil
      Nov 2004
      Palos Hills, Il
      I had one on my car........be careful, they are VERY soft and broke off Very easily.
      Windham, NH
      Quote Originally Posted by Hacker Joe View Post
      Thanks for the heads ups. It's on my car now, but I won't be driveable until Spring. I'll be sure to keep an eye on it.
      Phil
      Nov 2004
      Palos Hills, Il
      I broke mine installing it, once it is in I think it would be fine but I would definately keep an eye on it.
      Aug 2008
      Pgh, PA
      Old post - I know. But...
      Had no problem installing this last year. Now that the car has been on the road I find that this think spits oil all over the place. It's coming off.
      Moser 12 bolt.
      Jun 2006
      NW burbs IL
      The only solution is to get it vented up into the trunk, especially if the car is lowered.
      Matt
      Dec 2009
      Quote Originally Posted by Bow Tie 67 View Post
      Not sure if this confilcts with your post, but Art Morrision makes a puke can that mounts on the floor or trunk pan above the pumpkin. I've never seen anyone use this and I'll look for the link, but I am considering this as an option.
      Edit -- Here's the link, middle of the page:
      http://www.artmorrison.com/2006cat/48.pdf
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Dec 2010
      Quote Originally Posted by Ron.in.SoCal View Post
      This is what I have been using for the infamous spitting, it took several failed concepts before I went to the trunk. In a previous comment, he is correct, if you are lower than stock there is no room underneath, at least on an A-body. For reference I am running a 9" with Tru-Trac.
      iacovoni
      Cartersville, GA
      The puke can in the trunk is the best solution. I went through this type of vent, as well as the sintered bronze type, on a 4th Gen F-body I used to have. Both puked gear lube constantly.
      Joe Hinds
      Northwestern NJ
      I used one of these:
      Think it'll leak? it's what GM uses for tranny & axle vents.
      Tommy
      Tommy Souren
      "The older I get, the faster I was."
      Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
      Loganville, GA
      Tommy, I used that in my El Camino, no problems in street and autocross use. I didn't do any track days, so I don't know how it would do there.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Dec 2010
      Fredericksburg, VA.
      I don't have room for a hose fitting on my housing due to the location of a mount bracket. I needed a very low profile vent. I found a stainless steel porous metal on McMaster-Carr item #4456K12. We'll see how it works. If not I will need to weld up the hole and move the vent to the other side of the center section.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      san diego
      Google snubber. or an air compressor exhaust....
      Does anyone else have a solution to this problem?
      1967 Oldsmobile 442 W-30 w/ Fuel Injected E Block n C head 400ci, 2004r, Global West Everything, 3:70 Ford 9in, B-body spindle w 12in rotors w/ Wilwood calipers and11in Ford Explorer Disc setup in rear!! Alot of work!!
      Sep 2009
      Iowa
      Quote Originally Posted by 67w30 View Post
      https://www.pro-touring.com/showthre...e-installation
      //Ed
      //1964 Impala SS
      //1972 C10
      //1969 Camaro (hers...)
      Texan Back in Texas!
      This is what I am using on my 8.8. Have it mounted high on the rear 4-link cradle.
      http://www.summitracing.com/parts/LNG-22569/
      Nice kit with quality billet mount. I will have to wait until it is on the road to see how well it works.
      1965 Falcon Hardtop
      charleston, SC
      What thread/nipple size do I need coming out of the axle tube? Right now I just have an empty hole.
      Robert's 1969 Camaro - 2002 LS1/T56, 10pt cage, Global West Stage III front suspension, HTH truck arm rear suspension, Sprint Cup 9" full-floating rear end, Fikse Mach V 17" up front 18" in the back and still working on it...
