Results 1 to 15 of 15
New to Pro-Touring
- Jan 2005
- 64
End links for Herb Adams Sway Bar
I have a old Herb Adams 1 and 5/16 inch front sway bar for my 77 TA that is missing the end links. I was told I could use links form a corvette. I find these on the net and was wondering if anyone has done this and could steer me in the right direction.
http://www.ecklers.com/product.asp?p...LL-_-42263-_-X#
It looks like I would have to drill new holes in the A-arms to use that piece or am I missing something.
08-21-2009 #2
- Mar 2005
- 345
On a 1st gen the Adams bar uses similar links that you linked too (no pun intended).
The ends of the bar are turned upward with a hole through it. The heim end bolts to this part of the link with the swivel through bolt (does that make sense?).
On the lower A-arm, there is a steel block bolted to the original sway bar link hole. The lower heim end then bolts to it.
On the linked picture the way the heim ends are connected together is the same as the Adams bar. However, the swivel through bolts are different. The bolt head is at the heim joint, with the threaded portion doing the holding (?).
Right now it is pouring buckets of liquid stuff outside. I can get a picture or two later if it would help.
Bob
08-21-2009 #3
