Thread: Injector Cleaning Questions
08-12-2009 #1
I bought a new set of Ford SVO injectors and used them about 6 months. I then pulled the engine apart. That was 3 years ago. The injectors were left in the manifold but the intake was off the car and stored in a dry but unheated garage.
Should I have the injectors cleaned before returning them to use? Run a good injector cleaner through the tank and call it good? I'm on a fairly tight budget and just didn't want to spend needless money. Will they be okay as is?
What's your ideas?
Doug Gulley
09-09-2009 #2clean the injectors. i purchased a set of low mileage injectors that had sat for a while and had issues running rich at idle and lean under load. I spoke with the guys at FIC http://fuelinjectorconnection.com/shop/ . they informed me that gas will gunk up in the injector just as it does in an old tank and clog the injector. i think the cost was reasonable to clean them.
Aaron R
09-10-2009 #3Thanks. I had almost forgot about this post. I did some looking online and found some good pages on how to clean your injectors yourself at home.
Doug Gulley
09-26-2009 #4
