    Page 31 of 101 FirstFirst ... 21 26 27 28 29 30 31 32 33 34 35 36 41 81 ... LastLast
    Results 601 to 620 of 2014
    1. #601
      Jan 2010
      Calgary, Alberta, Canada
      Can I make a quick observation/advice based on my learnings on a similar setup? Make the LCA pick up points adjustable rather than UCA, they're drastically easier to move than the UCA. Plus, with the drastically longer links, the adjustment of one hole diameter results in a much smaller change to the IC.
      My $0.02
    2. #602
      san diego
      Quote Originally Posted by Wesley J View Post
      My $0.02
      I agree with what you said about smaller changes. However, for street and track setups I want a horizontal LCA to limit roll steer. The upper control arm mount will be slotted so that changes are small. I also has another mounting location on the housing for teh UCA. The LCA has an adjustable mount on the housing for track days at teh strip! I am adjustable for 55% to 130% maybe more if needed.
    3. #603
      TN
      Quote Originally Posted by Bryce View Post
      Have you considered, instead of slotting the UCA frame side hole, drilling a series of overlapping holes. This would provide the fine adjustment you want, but also positive locating because of the "nubs" and insurance against slippage as well. That is what I'm doing. I can draw it up if I'm not clear.
      Benjamin
      Twin Dusters
    4. #604
      TN
      Here, like this:
      it is a little harder to make, but I would say it would be worth it.
      Benjamin
      Twin Dusters
    5. #605
      san diego
      Quote Originally Posted by Bjkadron View Post
      I have thought about that but i dont think I can get a fine enough adjustment. Im talking about 1/8" would be fine tuning. Maybe thats the engineer in me being picky, but............
      There is no issue with a slot in a vertical direction, or perpendicular to the arm at ride height. There is not much force in the direction of the slot. Another idea is to slot it on an arc so that the arm does not need to have a length change.
    6. #606
      san diego
      Here, like this:
      Now you are just showing off you solidworks skills. NICE!
    7. #607
      TN
      Yeah 1/8 would be a little absurd, that would be a LOT of holes. I was going to go 1/4 on mine. Or the slotted arc. Actually If I make it on a CNC I might just do a series of holes arc in 1/8" increments! Nothing like over-doing it right?!
      Ehh.. Not really, I was just really bored there for a minute, and since I now have it at home... and you can't tell as much because of how I rotated it but the holes are on an arc.
      Benjamin
      Twin Dusters
    8. #608
      Mar 2010
      GR Michigan
      On a slotted adjustment, would it be too complex to add adjustment screws? They would be parallel to the axis of the slot to control movement and provide micro adjustability.
      Jeff
      73 Mustang Convertible
    9. #609
      san diego
      Jeff,
      I cant picture what you are describing. Maybe if I read it in the morning after some coffee my brain will work.
    10. #610
      Dec 2008
      Covina, Ca
      Hey Bryce, the car looks great and I like how you built the watts link setup.
      The picture below is what I think Jeff was thinking of, you can turn the screw and the whole pivot point moves up and down.
      Jon
    11. #611
      san diego
      Thanks Jon,
      That makes sense now. I dont have the room for a setup like that. That would be cool though.
    12. #612
      TN
      Wow... I had thought of that for Panhard bar adjustment and such, but never for the actual suspension mounts. Now I'm thinking I can fit that in if I cut the floor just a bit... Very cool idea!
      Benjamin
      Twin Dusters
    13. #613
      Dec 2008
      Covina, Ca
      Yeah, I was thinking about using it to as the upper link mount instead of my slotted mount. I would have to remake every thing, but will see what happens when I get the roll cage in. It is about $275.00
      https://www.circletracksupply.com/pr...3&cat=0&page=1
      I haven't gone searching for a cheaper price or a similar piece.
      Jon
    14. #614
      san diego
      And you were giving me a hard time for wanting fine adjustments!!!
    15. #615
      san diego
      Quote Originally Posted by jtomas801 View Post
      Jon
      jon,
      Post up a link to your car, I would like to see some pictures.
    16. #616
      TN
      No No No... I was saying it would be hard to do fine adjustments with the set-up I suggested. most of my adjustment is going to be in my upper link anyway, So I might as well be able to fine tune it. Besides, If I'm going to be a good engineer I have to get used to over-complicating things! Right?
      This idea would be really cool. But, the only thing I would want to add is a lock of some sort so it doesn't move during just regular street driving with the vibration and such.
      Benjamin
      Twin Dusters
    17. #617
      Ca
      Here is my crude concept to maybe solve your dilemma. I think it could work. Not to complex. this was drawn by me in two minutes. FWTW.
      Name:  mount concept.JPG
    18. #618
      Jan 2010
      I'd agree with Bryce, the arced slot is the best way to go. The force along the long axis of the slot would be minimal so the clamping force provided by a 5/8" fine thread bolt should be much more than required to keep it from moving IMHO.
      Bryce, I'm going to agree with you on the roll steer. I found adjustment to my AS to be meaningless as I have such little horsepower, although this wont be the case next year... The adjustments I made were to improve my roll steer, which was pretty bad initially. What I've found is that I'd like more fine tunability now that I'm in the ballpark. The problem is that you wont know the ballpark until spent a bunch of time tuning.
      Wes
    19. #619
      Dec 2008
      Covina, Ca
      I wish the picture above was from my car, but it is from a chevelle, http://www.chevyhiperformance.com/fe...lle/index.html
      Here is the link to my build, http://www.lateral-g.net/forums/show...t=26454&page=6
      Have a lot more to do but it is getting there.
      Jon
    20. #620
      Aug 2009
      Chandler, Az (from west NE)
      I installed a four link that had 1/8" adjustments provided for 5/8" bolts by having multiple sets of bolt in plates with each set of holes offset from the next. This allowed a full 5/8" of metal between holes so theere could be no slippage. Further modeling and subsequent track testing showed that only two sets of plates and 3 holes made all the difference needed, but provided a positive location for each adjustment used.
      Ric
      2002 s10, DD and AutoX.
      1966 Malibu owned since 1971. Drag car converting to track toy!
