      Nov 2004
      Forney, TX
      Oil filter x-reference....
      When changing the oil on my car, I noticed that there is plenty of room for a longer (and therefore larger) oil filter. I use a FRAM PH30 and I'm sure there is another FRAM filter out there with the same thread pitch, hole diam., and mounting surface - just longer. I did a search on FRAM's website, but it doesn't give any specs for their filters. I sorta remember a magazine article years ago about the interchangeability of some common filters. Anyone out there have a clue?
      __________________________
      Boyd
      1972 P/T Style Chevy Short-bed - coming soon
      Specialty Auto Services
      Nov 2004
      Forney, TX
      still looking for a x-reference but I did find this,
      http://www.cmfilters.com/index.cfm
      reasonably priced race-bred filtering technology. You keep the "shell" and change out the filtering media "insert". Interesting at the least...
      Boyd
      Jan 2003
      arizona
      X- Ref
      I'm guessing you have a small block chevy. The other Fram filters that fit the sbc are the ph5 w/anti-drain back, ph13 w/o anti-drain back and a couple other that I can't recall.
      Marcos
      1969 Camaro
      If you have a TON or room, you can use the PH373-it's a two-quart filter damn near!
      [email protected]
      Sep 2003
      Tampa, Fl
      If you have a friend that works at one or just hit up the auto parts stores every now and then for the old books, they come in very handy. I've been saving them since I started working in one many, many years ago. Then you also have a way to decode the part numbers as that info is usually in the book also. Examples are the spark plug, filters, and Moog/TRW books are ones I use a lot. The books are called the Weatherly Index if I remember right and although they use computers for everything now days they usually have the books also.
      Brian
      '68 Chevy Stepside-Fatman, HTH, 8.8, Baer, Hydratech, LS1/T56. I know it's a truck but you gotta start somewhere and I need the challenge.
      this might be a little off topic and some of you might have seen this before but since your on the topic of oil filters
      Oil Filter Test
      but i've pull apart a fram filter before to see for myself... the test was right. it was not a well built filter. as for the napa golds not a bad filter at all.
      personally i run a Mobil 1 ones, K&Ns, Napa Golds.
      just thought it was an intresting study.. take it or leave it.. but pull filter apart and you can come to your own conclusion.
      You Drive A What?
      "being close minded will get you no where" don't be a pro tour snob!
      florida
      hey boyd....i work at napa, if i can remember tomorrow ill pull my spec book out and get you the number for the longer filter.
      Tough guys may wear pink, but Bad Asses still wear black.
      Nov 2004
      Seattle area
      Quote Originally Posted by Maverick Man
      ..i've pull apart a fram filter before to see for myself... the test was right. it was not a well built filter. as for the napa golds not a bad filter at all.
      I've seen the Fram filters taken apart and it was enough to make me switch. I have Bosch filters on the Kia and Miata (same filter), Motorcraft on the Mustang and Puralator on the Firebird.
      T.B.
      '80 Firebird Esprit
      It's a Pontiac, how fast can it be?
