    Page 8 of 10 FirstFirst ... 3 4 5 6 7 8 9 10 LastLast
    Results 141 to 160 of 187
    1. #141
      Jul 2010
      Rancho Murieta
      Awesome Car
      You do really great (and fast) work! this thing looks great! i had a question about the rear end. Is that lower arm on there to prevent axle wrap/wheel hop since it's a mono leaf car?
    2. #142
      Houston, TX
      Quote Originally Posted by whayden2003 View Post
      Well just looked thru the whole post and I have to say great job on not only the work but I am very glad to see the great job of task management. You should be a example to all of how to start a job and finish it before moving on to something esle to often this is what happens to these great cars to many small jobs not finished turns a project to a basket case. Again great Job and thanks for taking the extra time to share it with us.
      Thanks. I like to start on small jobs on the car. That way I can easily finish it and move on to the next one. The body work on the car took a long time, and I've had to take a break from it. Glad that portion was over.
      Tu Ho
      Firebird V2-LS swap
    3. #143
      Merritt Island,FL
      Tu,
      Just read thru the whole thread, car looks great ! Post some pics of the kicks installed when you get a chance.
      Thanks,
      Brian
      Check out my web site.
    4. #144
      Dec 2009
      Los Angeles
      Awesome progress! It's looking great! I can't wait until I'm that far along...
      Long Live the Muscle Car
    5. #145
      Houston, TX
      Quote Originally Posted by Clutch93 View Post
      Clutch93,
      Sorry for not getting back to you sooner. The lower arm on the rear end is to prevent axle wrap. Automatic cars have one, whereas manual equipped cars have 2.
      Tu Ho
      Firebird V2-LS swap
    6. #146
      Houston, TX
      Some update. Been working steadily for the last few months.
      Test fitted the front speakers and Screamin Performance kick panels. The panels are high quality and they fit great.
      Picture of ds closeout panel
      Driver side kick panel with speakers
      Pass side
      Tu Ho
      Firebird V2-LS swap
    7. #147
      Houston, TX
      Installation of Vintage Air A/C
      System as delivered.
      Evaporator unit
      Cut the dash for center vent
      Center vent installed
      Side vents
      Evaporator installed
      Compressor installed. I brought the lines to the local A/C shop and had them crimp the fittings
      Modified the stock HVAC controls for V/A controls
      I tried to install the radio, but the evaporator is in the way. Since radio is just a dummy and not working, I decided to do some surgery on the radio housing. After 5 mins with the cut off wheel, I have this.
      Then everything got mounted up in the center dash. Just have to get a trim plate for the radio.
      Tu Ho
      Firebird V2-LS swap
    8. #148
      Houston, TX
      My first attempt at installing headliner. I measured the centerline on the window frame (front/rear) and lined it up with the centerline marked on the headliner, then stretch the headliner out and clipped it in place.
      Headliner glued in place. There are still some wrinkles toward the center, despite my attempts to get it smooth. Hopefully it will tighten up overtime, otherwise I may have to redo it.
      I started hooking up the transmission linkage. I bought the outer shift lever from CI for a 67 and they sent one labeled 67/68. However, 67 cars have round holes for the linkage rod, whereas 68 cars use cables.
      So I went from this...
      to this, after some welding, grinding and drilling.
      Tu Ho
      Firebird V2-LS swap
    9. #149
      May 2009
      Minnesota
      Wow you have been busy. It looks like it is coming along very nicely. If it's not to late can you take some pictures of how you routed any and all wiring that is still showing. Mine was pretty gutted when I tore my old wiring out. Also any tips on the vintage air. I'm a couple of years out from buying and installing but any tips would be great.
      Thanks for any help Tu.
    10. #150
      Houston, TX
      Quote Originally Posted by 68400BIRD View Post
      I have pictures of the original wiring inside the car before I took them out, and some of the new wiring before I installed the carpet. I can post those up on your project thread. I don't have anything from the firewall forward, since I bought the car without the front end. I'm rewiring the car with Classic Update kit from American Autowire, and they made some changes to the engine and front light harnesses so the wire routing will be different anyways.
      As for the V/A set up. It's very complete. I actually enjoyed working on it since I did not have to hunt down little parts. They provided everything, right down to the little screws. One thing I don't like about the kit is the crappy supplied block off plate for the heater box opening. It looks really tacky when installed. If I were to do it again, I'll go with DSE firewall closeout panel for a better looking install.
      Tu Ho
      Firebird V2-LS swap
    11. #151
      May 2009
      Minnesota
      Thanks Tu, I also bought the AAW update kit. I welded up my firewall so it is all flat already. But I was worried about how I was going to hang the unit under the dash. I don't really want to drill any holes in my clean flat firewall.
    12. #152
      Houston, TX
      You may want to check with DSE. I think they make a bracket for the V/A unit that allows you to mount the evaporator without drilling holes in the firewall.
      Tu Ho
      Firebird V2-LS swap
    13. #153
      May 2009
      Minnesota
      Tu, here are a few pictures of my exhaust. It's not complete and I am still not happy with the fit.
      This first picture is where I think it is best to start since none of the back pipes get cut. Get the mufflers positioned in the xpipe to just hold them in place. Slide the pipe in that goes over the rear end and then push the whole assembly back until the prefabbed brackets touch the rear floor.
    14. #154
      May 2009
      Minnesota
      Check out this link it might help some also.
      http://forums.performanceyears.com/f...d.php?t=625549
    15. #155
      Houston, TX
      Thanks Rob, I found the same thread while searching on PY. I still have the original hangers on the car, so I may try and use those. There are some installation pics of a 69 FB on Pypes web site showing the original hangers being used. I did the mock up on one side and looks like I have to trim the legs of the x-pipes and down pipes quite a bit.
      Tu Ho
      Firebird V2-LS swap
    16. #156
      Mar 2011
      Sweden
      Nice work and the car looks awesome!!!
    17. #157
      May 2009
      Minnesota
      Keep me updates as to how your install goes. I plan on starting on mine again this week. Like I mentioned on the phone I think I might need to cut the pipes coming out of the mufflers and going over the axle. In order to get enough clearance so the pipes do not hit the rear frame rails I need to have my mufflers hanging down to low.
    18. #158
      Houston, TX
      I had the rear tail sections mocked up tonight. Took me awhile to figure out the pipes. They (Pypes) need to redo the angles on the bends of the pipes as the mufflers are hanging a bit too low, not below the differential though. My camera battery died so I'll have some pictures this weekend.
      Tu
      Tu Ho
      Firebird V2-LS swap
    19. #159
      Jun 2010
      Tu, looking great keepit coming! Cool to see the VA and headliner install, will be going through the same soon!
      Gui
    20. #160
      Houston, TX
      Quote Originally Posted by geberhard View Post
      Gui
      Gui, check out post 179 in this thread at team camaros.net for a youtube video of a headliner install. Very informative.
      http://www.camaros.net/forums/showth...install&page=2
      Tu Ho
      Firebird V2-LS swap
