      Feb 2008
      Texas
      12 Bolt Rear End Advice
      I just picked up a 71 El Camino 12 Bolt code read CFC which should be 3.31 posi. I noticed the wheels didn't turn in the same direction thought it might be due to worn posi unit but I opened it up and it had 2.73 and was aa open rear end. I paid $500 so not to bad the guy thought it was open I don't know why someone would take out the posi and 3.31 for open 2.73?
      Anyways few questions:
      1. Before I took out the carrier the pinion and ring would not spin do I need to add some sort shims? The teeth look great they just seemed to be bound up when fully installed. I'm new to rear end stuff.
      2. While I have everything out should I upgrade to a posi and a higher gear like 3.31 or 3.73. My application will have a LS1 with T-56 daily driver. Pretty basic maybe down the road add a twin turbo setup.
      3. If yes to upgrading to the posi and gears wheres the best place to buy them? Also what else should I replace while I have it apart?
      Thanks for the help.
      May 2002
      Northern California
      When you put it together you will have to adjust lash. It might have been a bearing hung up or something.
      4:11's would be perfect but your tire size would help with selection.
      Thanks for the help
      https://www.pro-touring.com/forum/member.php?u=6990 PM this guys, he can help you with all you need.
      Don't forget Frank at Prodigy customs too.
      Also congradulations on the rear. Thats a great price.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Feb 2008
      Texas
      Thanks MrQuick
      Tire size not sure I would guess 17" 18" wheels with 315/25/R17 or 18 I think thats the biggest I can fit right? Its a stock 70 Chevelle
      Feb 2008
      Texas
      So 4.11 would be better for power and daily driving kind of driving?
      Sounds like someone just stuck this thing together to sell it. I can help you with the parts. Let m eknow what you are interested in and I'll help you get the right stuff.
