      Put this in order for me
      Im buffing with liquid Ice when done I have, Swirl remover,polish,glaze/sealer,wax
      In what order and means of aplication should I use
      Example
      1)liquid Ice wool pad w buffer
      2 swirl remover. terry cloth w orbital
      3 polish w polish pad buffer ETC
      Dec 2007
      michigan
      I've never used that brand before, but if your not sure, make sure your buffer is not going over 1500 rpms. The one I use is actually right around 1000 rpms. I use 3m course, fine, and micro finish compounds with different pads, wool pad, red foam pad, white foam pad, then go to an dual action buffer with microfinish compound to get rid of the swirls. This seams to work ok for me, but I'm not an expert painter and have only done just over a dozen cars.
      oh yeah, if your car is just recently painted, hold of on the wax and polish for awhile. you want the paint to be able to cure. The last thing you want is the paint to cloud up on you.
      Im sure others on here have better suggestions, thats just what has worked ok for me.
      2005 CBR 1000RR..."mostly stock".
      1968 camaro... "in the works".
