    Results 1 to 15 of 15
    Thread: 79 T/A build
      Jun 2009
      williston ND
      79 T/A build
      its a tenth anniversary car i have had since march 01. its now going under the knife. im installing the competion engineering ten point with chris alston chassisworks bent rear struts. comp sub frames conn. i am going to be making it into a hard top, i have a factory donor roof. looking at kens spped and machine out of flordia to build a aluminum 535 with cv1 heads. keisler tko600, protouring f body competion suspension. wilwood disc all around the car will be repainted factory 10th anniversary style with correct decals. factory interior with painted cage and auto meter gauges. just need imput along the way some parts maybe switched out if someone else has had better luck or knows of better products. thanks guys
