Results 1 to 12 of 12
Thread: Gas Tank Vent
06-28-2009 #1
Gas Tank Vent
on a 69 camaro where is the gas tank vent suppose to connect to ?
It a stock tank that has been sumped. I have a vented gas cap, but when I run the car for a few minutes and then shut it down the gas shoots out of what I believe to be the vent.
It's located on the passenger side of the tank.... Where should this connect to ????
HELP !!!!
Joe C
1969 Camaro
06-28-2009 #2
- Jan 2006
- Garwin, Iowa
- 241
Is it one of the two lines coming out of the factory sending unit? If so I would think it is the factory return line. If you're running a pressure and return out of the sump, I would cap and clamp the two factory lines. Because both lines are submerged, any pressure in the tank would push fuel out.
06-28-2009 #3I don't think it is coming from the sending unit. Is looks like a factory vent that is located on the rt side of the tank.
Joe C
1969 Camaro
06-28-2009 #4
- Jan 2006
- Garwin, Iowa
- 241
I was thinking they didn't use a vent on the tank until 1970, when they started using evap canisters. I could be mistaken.
06-29-2009 #5I tried taking my gas cap off yesterday after I heated up the car. Nothing poured out of the vent line after that.
Could my cap be bad ?Joe C
1969 Camaro
06-29-2009 #6
