Results 1 to 20 of 23
06-26-2009 #1
Watts Did you say? Pivot loading. ??
Im using 1.25 IDx 2 inch needle bearings and a 1.25 x 2inch Axle with 3/4 grade 9 axle bolt. Should I make a bracket to put the Axle bolt in double shear or will I be OK in single with the 3/4 grade 9. This is a frame mounted Watts...
Also are 5/8 chromemoly 14,485 PSI teflon lined Heims with grade 9 bolts OK for the links. ...
Thanks guys I did search with no results did find one post about the same with no answers. .
