      Socal, Ca
      4L80-E tailhousing question
      Hi guys,
      If I run a 4l80-E with the bowler tailhousing with mechanical & VSS sensor, must I run the Compushift trans controller?
      This will be hooked to a carbed chevy 350.
      David
      If you want the transmission to shift automatically you must run a controller.
      There are several options for controllers. Compushift, PCS (now TCI), and Baummann.
      You could also use a full manual valve body setup and not use a controller. I build many 4L80Es this way for the mostly strip guys but I encourage people to use a controller and get the benefits of the electronic control.
