    View Poll Results: What size tires???
    Voters
    18. You may not vote on this poll
    • 285/40/18 (26.97" tall) rear tire
      7 38.89%
    • 295/35/18 (26.12" tall) rear tire
      10 55.56%
    • 245/45/18 (26.68" tall) front tire
      4 22.22%
    • 255/40/18 (26.03" tall) front tire
      7 38.89%
    • 275/35/18 (25.57" tall) front tire
      6 33.33%
    Multiple Choice Poll.
      "New" 2nd Gen Rim/Tire Poll
      Thanks for all the input on this delimma!!!
      The grey centered CL205s are leading the poll by a 4 to 1 margin!
      I'm now looking at either 245/45/18s or 255/40/18s up front with the 285/40/18s out back... rims and tires will run me $2300-$2400.
      I just found out I've been select for promotion in the Air Force
      to Senior Master Sergeant (E-8) and the wife has given me the
      green light for the new rims tires.
      Know of any other rim in the $360 per rim range??
      It may not be a bunch of money to some but I won't get a second chance at getting this right after the purchase...
      Thanks for all your comments and advice!
      V/R,
      Ty
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
      Mar 2003
      Boringville
      Use these sizes!!
      Here are the pics i promised.
      18x10 on back with a 295/35/18 5.5" backspacking
      18x9 on front with a 275/35/18 5.0" backspacing
      Nice Camaro!
      Thanks Yody!
      What rims are those? Tires??
      Is there any problem with the front tires rubbing at all??
      Are those brake cooling ducts formed into the quarterpanels???
      V/R,
      Ty
      Mar 2003
      Boringville
      no, those ducts don't do anything, he has custom T-tops, the shelby scoops you see, a smoothed rear spoiler, and transam vent extractors in teh fenders. Those are boyd coddingtons with yokohama tires. he doesnt' have his frontend back on yet so don't know if it rubs, if it does, he will just put a third gen transam steering box in, that is fast ratio and also reduces your turning limit so it won't rub
      Is that an all-stock suspesion or is anything modified?
      Do front tires rub???
      Yody,
      Any idea how soon he'll have that front clip back on?
      I definitely like the look!!! Just don't want any hassles
      with tires rubbing with my new wheel/tire combo.
      V/R,
      Ty
      Mar 2003
      Boringville
      just deal with it, everything on these cars "rub" its worth it to me, front clip won't be on for a month or 2
      Jun 2002
      Benicia, CA
      Good size that fits well with minimal tweaking.
      My 71 Camaro has had 17x9.5's on all 4 corners. The rears fit fine but the fronts did rub a bit, even after I modified the inner fender wells. I was contacting the sway bar, rubbing paint off. For minimal stress over tweaking I determined that 10" wheels (measuring 11" wide) would fit great on the rear, and if I rolled the lip it would be even better. The front would fit 8.5-9" wheels, but in order to keep them inside the fender lip I needed 19" wheels to clear the tie rod ends, upper ball joint, etc. with no problems at all.
      This afternoon I tried a 19x8.5" wheel with 255/35/19's (I think they were 35 series) and 5.5" bs and it fit very well, maybe 5.0-5.25" bs would be better but I did not have a 1/4" spacer handy. The nice thing is that the overall diameter of the tire was about 25.7" and was close to hitting my inner fender well, so a 40 series or larger would definitely hit on my car. It looked great on the car, wish I could have driven it. I did turn the wheels fully each way in order to see frame clearance and everything looked great.
      I like my car fairly low, so the tire/wheel package must be inside of the fender lip to eliminate contact. I've had tire rubbage at speed before, not fun and I definitely worried about tire failure at the wrong time...
      Jeff
      1971 RS Camaro: PAINKILLER
